T-Belt time with questions about hoses
  • 325YOY
    • 142
    Time to do the belt with all the goodies and have done some searching when it comes to coolant/radiator hoses and I'm still a little confused. I really don't want to replace every hose on the thing but do want to do the most critical and the ones most prone to failure. Any guidance is appreciated. TIA
  • e30serg
    • Dec 2006
    • 562
    You might just want to replace all the hoses. Rubber hoses that are that old sometimes won't seal after you disturb them. Why chance it?
    Also, take a look at the tube that cover the CPS wire as it goes around the front of the engine. If the little clips that hold it in place are broken, the plastic tube will rub on your belts.
    • dj01540i6sp
      • Jan 2009
      • 349
      Crank Shaft Front Bolt
      You do not have to remove it unless your front seal is bad. There is no where that says not to it just says to do it. It is virtually impossible If you have to I have read here some people use impacts if you got a good one and some use a breaker bar and hitting the ignition to turn motor with starter but unplug the coil.
      Good Luck
      DJ
      • Flash
        • 688
        Go ahead and order all new hoses, timing belt and tensioner, camshaft oil seal and o-ring, the rubber cover on the drivers side of the upper timing cover.
        Waterpump interval change is every other timing belt, if you do not have notes of the last time it was changed, do it. They are only 45 bucks new with the gasket.
        Also buy new the plastic cover on front with the clips if your timing cover has the provision for them (sometimes people have replaced them with the ones without holes.
        Like serg said ^^^^^ hoses dont always seal once disturbed, im fighting this at the moment until i do my engine swap.
        Bavauto should have a complete hose set for your car to save time looking for part number.
        Coolant should be phosphate free if you dont plan on using BMW brand coolant.
        HTH
        • Devil Inc
          • Jan 2008
          • 802
          Umm...Water pump interval is the same as the timing belt, roughly every 60k.
          • 325YOY
            • 142
            HTH
            Yikes! Hoses alone from Bavauto run $179 and are $93 from Autohausaz
            • Ben Carufel
              • Jun 2004
              • 5248
              I just bought all the timing belt goodies last week for an '88 325iS:
              Big Radiator Hose: $10.50
              Upper Radiator Hose: $11.95
              Lower Radiator Hose: $6.50
              "3-Way" Radiator Hose: $38.00
              Water Pump: $48.00
              Thermostat: $14.50
              Valve Cover Gasket: $7.25
              Valve Cover "Doghouses"; $0.85/ea (need 4)
              Timing Belt Kit: $29.00
              Air Filter: $8.95
              Fuel Filter: $12.50
              Alternator Belt: $3.75
              Power Steering Belt: $3.50
              Oil Filter: $4.95
              Spark Plugs BOSCH W8LCR: $1.85/ea (need 6)
              Intake Boot: $18.50
              Distributor Cap: $44.00
              Distributor Rotor: $18.00
              Those prices are all from Northside Imports in San Diego:
              Chris is who I talk to there.
