Can anyone in the south bay help me bend my shift lever?
  • shiftbmw
    • Oct 2005
    • 2012
    Hoping to find someone in the south bay that can help me bend my shift lever. I would likely need to make use of your press or vise(I'd come to your place of course).
    I have a cheap chinese drill press vise but my shift lever was too much for it(steel makes a loud sound when it cracks).
    If anyone's willing to help out, that's be awesome.
    Thanks!!
    "The best argument against democracy is a five-minute conversation with the average voter." - Winston Churchill
  • HiTheNameIsBJ
    • Jan 2009
    • 1116
    why not just heat it up first?
    • shiftbmw
      • Oct 2005
      • 2012
      The only sources of heat I have are my oven, my heater, and the sun. :-)
      • e30serg
        • Dec 2006
        • 562
        If you're around Oakland I can give you a hand.
        • shiftbmw
          • Oct 2005
          • 2012
          Thanks!! I'm up that way occasionally so that may work. Do yo have a sturdy vise/press or something similar?
          • 88e30is
            • Feb 2007
            • 690
            What are you trying to do?
            • shiftbmw
              • Oct 2005
              • 2012
              Bend my shift lever so it sits vertically in my car.
              • 88e30is
                • Feb 2007
                • 690
                Why is it not vertical already. Sorry maybe I'm just really tired and not getting it.
                • gazellebeigem3
                  • Jun 2005
                  • 3712
                  24v swap with a g260 is one reason, but it could just be a weird combo of trans/arm/shift lever/mounts/etc.
                  Its probably the michigan thing...
                  • shiftbmw
                    • Oct 2005
                    • 2012
                    When you try to fit a shift lever from a different car into an E30, the angles aren't quite the same. Search around for some pictures and it will explain. The X5 lever is the most obvious example.
