Failed emissions test
  • madvillain
    • 19
    HC
    15mph Max: 135 Meas: 196
    25mph Max: 110 Meas: 193
    CO (%)
    15mph Max: 0.83 Meas: 3.90
    25mph Max: 0.63 Meas: 3.51
    Anyone know where I should start looking?
  • hugh jass
    • 2220
    what car? have you done any maintenance on it? how old is the cat?
    ______________________
    ex-Chief Operating Officer
    Blunt Tech Industries
    West Coast and Pacific Rim
    • madvillain
      • 19
      86 325es, the only thing i have done was changed the oil and pour in a bottle of fuel injector cleaner. the cat is probably as old as the car.
      • TexasTerp
        • Jan 2009
        • 3541
        Spark Plugs, Air Filter, Fuel system cleaner, Oil Change,
        Conditions of:
        Exhaust system - any holes, severely rusted areas?
        Catalytic Converter - how old, rust?
        Pipe Gaskets - rusted out, new, old?
        O2 Sensors - working properly?
        Gas Cap - pass vacuum test?
        EDIT: run a complete fuel system cleaner through a 1/2 to 3/4 tank, Flush your oil and refill completely, Get a new Air filter and check the intake system (boot, box and all) for holes, leaks etc, Get new Spark Plugs!
        stephenbrody.com
        • iignite
          • 125
          new o2s and methanol hydrate.. 8)
          no, but you might need to check for fuel, since you're running leaner than usual, hence the higher HC
          • E30_fiend
            • Apr 2006
            • 7348
            high HC's usually point to a bad cat. it probably wouldnt hurt to get a new one. its done its job for 22 years lol
            • mikekristine325ic
              • Nov 2008
              • 338
              Tune-up and a Cat and you should pass. Mine did the same in my M20b25 vert. I had the original cat on it with 300,000 miles on it. I changed it out to a Magnaflow Hi-Flow and passed smog with flying colors.
              sigpic...
              1991 325is- Current Project w/ 150k on the clock
              1990 325ic- SOLD w/425k on the clock and still ran!
              1985 528e- SOLD
              1972 2002tii-Should have never sold it!
              • E30SPDFRK
                • 5713
                no, but you might need to check for fuel, since you're running richer than usual, hence the higher HC
                fix'd
                My vote goes to cat as well, but a tune up wouldn't hurt.
                Byron
                Leichtbau
                • Knockenwelle
                  • Jul 2008
                  • 395
                  Those numbers say RICH
                  Mike
                  '91 325i track car. Mostly...
                  • DatUtahGuy
                    • Jan 2007
                    • 3146
                    Just get the hookup and get it passed already
                    YOUTUBE: AR Perez
                    If lucky, the E36 will die peacefully, in its natural habitat, and be given the prestigious honor of donating its parts to an E30
                    • BraveUlysses
                      • Jun 2007
                      • 3781
                      Did they give you any NOx readings?
                      • iignite
                        • 125
                        oops, got confused with HC and NOx..my badd...
                        • madvillain
                          • 19
                          Yeah I definitely will give it a tune up and a new cat. Although there is this strong smell that the car emits, just not sure where it's coming from. Almost like fuel that is unburnt. I have passed the NOx part of it.
                          • BraveUlysses
                            • Jun 2007
                            • 3781
                            If you passed on NOx you're probably running rich, so that does sound correct if you're smelling fuel.
                            • madvillain
                              • 19
                              did a compression test and here's what it checked out. 3 cylinders are low
                              cylinder from front of the engine to back
                              1 155
                              2 130
                              3 110
                              4 150
                              5 155
                              6 125
                              just wondering why its dumping a ton of fuel, because when i pulled out the plugs i can smell fuel.. and they are new plugs too.
