Center bearing mount/balance of driveshaft
  • GT BMW E30
    • Nov 2008
    • 2491
    From the beginning. My guibo (#2) was shredded. I replaced it. Still had a slipping/wobbling effect. Then I changed center bearing mount (#10 with its other conponnents) but did not mark how I took it off. Still getting a slipping/wobbling effect. Changed LSD. Still the same. Ordered another Center Bearing Mount form BMW and the parts guy told me since I did not mark the drive shaft then it will need to be balanced.
    1. How do I get this done? Should I buy a new drive shaft
  • BakesE30
    • Jul 2008
    • 231
    Every driveshaft I have pulled has had a white dot on each half of the driveshaft that you line up. If those are gone, try lining up the u joints before going out and spending money
    • SamE30e
      • Sep 2007
      • 4319
      Driveshaft isn't phased properly, like Bakes said, look for the white marks and line them up, it should dissapear.
      1985 325e 2.8 Turbo VEMS
      • ejnight
        • Apr 2007
        • 3488
        Originally posted by same30e
        driveshaft isn't phased properly, like bakes said, look for the white marks and line them up, it should dissapear.
        +1
        http://raceskids.com/
        • GT BMW E30
          • Nov 2008
          • 2491
          Thanks guy will look for dot. Hopefully this weekend I got it parked now cause I started to hear metal grinding.
