Jordan and I made one of these for less than $4, and Ken was doing the same. Look at this bullshit. Just one more reason why I don't give any of my business to Bavarian Autosporrt anymore.
NEW! Shave seconds off your shift times with the Hammerstand! You waste a lot of time during shifting because you must depress the clutch pedal beyond its true disengagement point. With the Hammerstand, you¹ll enjoy perfect shifts every time. Just step on the clutch pedal as hard as you like the Hammerstand stops the pedal at the optimum position. No more wasted motion or unsynchronized clutch engagement. It¹s machined from a solid cylinder of 303 stainless steel for strength and durability. It screws into factory mounting location. And it¹s infinitely adjustable so you can set it at the precise point where the clutch fully disengages. NOTE: will not work on BMWs in which the clutch pedal must be depressed to start the engine.
HAMMERSTAND - Hammerstand Clutch Stand - $79.95
