Rear Bumper Disassembly!
    Boy disassembling a plastic rear bumber is a giant PITA. For a while I didn't know if I was going to be able to get the center section off without breaking all of the clips.
    they are not built to be taken apart, they are built to be put together.
    -Andy
      and they do that well
        spray penetrating oil on all the tabs first, then take needle nose pliers and carefully bend the tabs so they are in the center of the hole, then push out the tab through the hole. repeat until you run out. simple enough
          Good info der. Thanks! I still have to take the ones on my 1990iS apart to put the one on that I got from the 1991 325is back on. Your tip will make it much easier. I don't know why I did not think of that. I probably just got to bullheaded with the other ones.
