Where can I find this bolt?
    New e30 owner, the car I purchased had a bad leak coming from the camshaft seal. Got to the issue, bad o ring. Cleaned everything up, replaced the seal and o ring and proceeded to put her back together when i snapped the second bolt. No biggie, got the bolt out nice and gentle. tested the threads with the other good bolt and everything is good to go. Only problem is, Im having a tough time finding a replacement bolt. Thanks for any help. (the pic is from google, but its one of those two bolts)
    Try to visit a Fastenal location, just bring in the good one and they will match it for you.
    1990 BMW 325iC Triple Black Hard Top, Self-Wrenched, Original Owner Family
      M6x18mm
        M6 standard pitch, M6x1.0x18mm.
        "Tires are our fuse" -Matt Juengel
        1986 325e Sedan | M20B27 parts available for sale |
          That's a familiar looking photo! Glad to see it's showing up in Google images.
          Previous posts got it, here's the RealOEM link if seeing the diagram is helpful, it's part #6:
          https://www.realoem.com/bmw/enUS/sho...diagId=11_1910
          ClassicBimmerBits.com
          Garage:______________________________________
          -1989 Alpinweiss II 325i - Other Daily Driver
          -1989 Zinnoberrot 325i - Daily Driver
          -1974 2002 - Weekender
          -1989 325ix - Totalled :(
          -1981 320i - Sold
          -1986 Porsche 944 Turbo - Sold
            you probably wont be able to find 18 mm unless you go to a bmw parts place the average hardware store will have 15/16mm or use 20mm and trim it. check make sure whatever you use doesn't bottom out and make sure there is enough threads engaged
              Even a 12mm bolt would be plenty. There is practically no shear or axial stress being applied to those bolts when the engine is running. Just to keep it from falling out is all. The ears break off those seal housings all the time, and many engines are running with only one bolt with no issues.
                dont disagree but yeah depends who's tightening though and later on it might be someone else. non mechanically minded peeps have a habit of stripping or breaking things in the attempt to tighten things death.
