3rd Gear Hitting Console
  • Bimmerbrain
    • Jan 2020
    • 14
    I have a 1991 325i and am just about done with a manual swap. The transmission is out of a 87 325i and linkage likewise. Last night I put the interior back together and in 1st,3rd, and 5th but mainly 3rd gear the shifter hits the console. If you barely push the lever into 3rd it wont hit the console but if you put any force behind the shift motion then the lever hits the console. This is also without the boot inserted yet.
    I have checked all that I can think of. Bushings had recently been replaced before in the donor car. And when in gear there's not very much slop and reverse does not hit the console so I dont think its the bushings.
    The only thing I can think of next is the "sheet metal" carrier bushing. Any ideas on what could cause the shifter to sit more forward in the opening than usual?
  • Ausatz
    • Apr 2017
    • 38
    Do you have your shifter in backwards?
    In the attached picture, the front of the car would be to the right
    E30 build by Austin Kratz, on Flickr
    • Zambuzan
      • Nov 2017
      • 434
      I installed my shift selector (z3) backwards but it doesn't touch the console (too lazy to fix it haha). Make sure the right side of the console sits flush against the dash...
      But it looks like you'll need to disconnect the linkage from the bottom and flip the selector 180 degrees. It'll be a pain but I'm pretty sure you won't have to disconnect the driveshaft.
      Good luck!
      "Time doesn't heal anything... It just teaches us how to live with the pain." - My Cracked Dashboard
      • Bimmerbrain
        • Jan 2020
        • 14
        I'm thinking that might be it. I don't have the driveshaft or exhaust on so it should be very easy to try that. Thanks
