E30 Mystery hose- where does it go
  • Rainman43
    • 3
    Hi, I recently tuned up my 1990 325i, and removed the intake manifold to clean it, and all the nearby hoses, etc.
    After reconnecting almost everything, I had one hose left, and could not find where to connect it.
    A photo is attached. The hose starts on the Charcoal canister, and runs up toward the throttle body.
    The photo shows the hose plugged with a bolt. The car runs fine as is. Any suggestions?
  • whodwho
    • Jun 2008
    • 1547
    There is a big brass nipple coming off the bottom of the throttle body pointing straight down towards it
    Edit - here is a good pic of where it goes
    https://www.r3vlimited.com/board/for...08#post6794008
    My M20 Frankenbuild(s)
    4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
    • Rainman43
      • 3
      Whodwho: Thanks, you are right! Once I mounted the Throttle body, the electric box underneath it blocked my view of the brass fitting.
      I had to remove the throttle body to access that fitting, and attach the hose from the charcoal canister. It's al buttoned up now, running
      100%. Thanks again. Ray
