1987 325is locking issues
  • cturner
    • Jun 2020
    • 2
    I have read many other posts on R3vlimited, but have not found another post with the same issue as mine.
    The door locks worked perfectly fine until a few days ago. I have a keyless entry. When using the KEY in either door, both doors will lock and unlock. When doors are locked, the keyless entry will UNLOCK both doors. The issue I am having is that the keyless entry fob will not lock the doors, but only unlock once I have manually locked the doors with the key.
    Could this be a door sensor? Before I was having issues, the doors would not lock when they are open, so I’m thinking it’s probably a sensor thinking the doors are open when they are closed causing the doors to not lock?
    Thanks much
    carson
  • Stanley Rockafella
    • Aug 2011
    • 4062
    If you really want to fix the issue, get rid of the keyless entry and go back to the OEM setup.
    IIRC, BMW still makes the door lock rebuild kits.
