Need help ASAP Will not start?
  • ejnight
    • Apr 2007
    • 3488
    No fuel. Fuel will pump if I ground relay. spark is good. I was doing an M30 AFM swap and it all went bad. its back to stock but it still will not start. why would it not turn on the relay? I even installed spare ECM and and a new relay, that did not work. Ground is good. Please help. I need to drive home.
    Thank you in advance
    http://raceskids.com/
  • Adrian_Visser
    • Jun 2006
    • 2823
    the main relay is right next to the fuel pump relay check that too, it supplies power to the fuel pump relay coil. You probably bumped it loose and broke a wire or something when you were doing the install, iirc it is the front of the two relays on the left shock tower the fuel pump relay is the back one.
    '89 Alpine S52 with goodies
    • ejnight
      • Apr 2007
      • 3488
      Fixed / New plugs. They must have fowled out with the M30 AMF in there. Back to stock AFM and New Plugs and Fired right up.
