My car hates me
  • Jean
    • 18228
    My car hates me
    Driving to lunch it started overheating and got quickly into the red. Stopped on a way, popped the hood and saw coolant on the driverside under the intake manifold trying to get out under pressure.... F ME.
    Just replaced the head/manifold/gaskets and now this... let the car cool down and drive a couple more blocks home and let it cool down. Managed to replace the coolant hose going from the side of the block to the t-body. It's always something you don't replace, at the worst possible time it will leak.
    So, replace those old lines before they become a problem.
  • Liam
    • 753
    No, it doesn't hate you, it just has that middle age thing going on.
    I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
    • GT BMW E30
      • Nov 2008
      • 2491
      My car is draining me know with driveshaft, axle, dif., transmission etc.
      • rThor432
        • Feb 2007
        • 3907
        Yeah when I re-sealed the S52 the only thing I didnt touch was the oil level sensor in the E34 oil pan. Can you guess what the only leaking component on the motor is?
        Good thing that you have a bullet-proof M10. Should be alright, even though it saw the red. Hope so.
        • mitch500
          • Jan 2006
          • 1092
          Originally posted by GT BMW E30
          +1
          you spekish engrish?
          1988 e30 alpine white vert 5speed
          1987 e30 325 eta
          1983 e28 533
          2001 x5 4.4l
          1997 e36 M3 Alpine white 5speed
          1991 Jeep XJ I6 4.0
          • Jean
            • 18228
            The oil level sensor? LOL. Yeah, running fine now below 1/2 mark on the temp gauge.
            I learned my lesson, the m30 is getting all new gaskets (leaving the head gasket alone though) even if they aren't leaking. With the engine out of the car it only makes sense to do those now.
            • rThor432
              • Feb 2007
              • 3907
              Might want to consider doing the M30 head gasket while it's out. Those head gaskets will start to seep/leak between 5 and 6 with a lot of miles. You've probably heard that before, but I'm tossing it out there. M30 headgaskets are really easy to change out, especially while you've got the motor out.
              • Collin
                • 1736
                It's funny because my thermostat to pump line just blew. Thank god it was 15 bucks and 15 minutes to replace.
                The Keystone Killers
                With 73k+ post, you'd think he'd have learned a little about life.
                • Ray Smoodiver
                  • Jun 2004
                  • 8809
                  In soviet Russia, you hate car.
                  • Collin
                    • 1736
