E30s on 17s - post yours
  • RoJo987
    • Nov 2017
    • 2
    #841
    17x7 ET40 Rial’s w/12mm & 20mm spacers
    Hello from Toronto, Canada! ‘91 318i 5-spd
    • amiller07
      • 930
      #842
      got rid of my coupe and snagged a touring. Finished the 5lug swap in about a day.
      "no, i didnt slap u...that was my hand giving ur face a high five"
      • roznic
        • Mar 2013
        • 2879
        #843
        Sexyness^^
        Which 5lug did u use and what's the wheels spec?
        • amiller07
          • 930
          #844
          Originally posted by roznic
          Sexyness^^
          Front is 96+ m3 with offset cabs. Rear is z4 hub with e36 m3 rear rotors and calipers using a set of Ngampleh's adapter brackets that I bought in 2016 when he started making adapter bracket kits.
          Wheels are 17x8.5 et13. Plans are to go lower or bags since I kept the fronts from my coupe
          • roznic
            • Mar 2013
            • 2879
            #845
            Wow, any issues with figment? Which tire size u're using?
            • amiller07
              • 930
              #846
              Running this setup is actually pretty good. I could run a meaty tire if needed in the rear but the front I am a little limited it on how hide I can go but it's currently on 195 40 17 Was thinking of pulling wheels apart and making them 9" wide and going 205 40 for a little more comfort
              • roznic
                • Mar 2013
                • 2879
                #847
                Do you by chance have a close up pic of the tires, to see how "stretched" they are lol
                • e30m3s54turbo
                  • Jun 2010
                  • 3290
                  #848
                  Test fitting 4x100 17x8.5 3pc Hartge wheel with Toyo RA1 255x40x17 on the rear.
                  For the front 17x7.5 with RA1 235x40x17.
                  Untitled by Raul Salinas, on Flickr
                  • potatomash
                    • Nov 2014
                    • 203
                    #849
                    17x8/9 Volk CV Pro 4x100 235/40 and 215/40
                    T U R B O - M 2 0 - B U I L D
                    M U S C C O O
                    • add1ct
                      • Feb 2014
                      • 14
                      #850
                      Azev type A 17x9.5(f) 205/15r17 and 17x10(r) 225/35r17
                      [/URL]
                      [/URL]
                      [/URL]
                      [/URL]
                      [/URL]
                      • hyperE30
                        • Sep 2009
                        • 2202
                        #851
                        HyperWerkz
                        89 mtech2, s50, AR Kit, borgwarner s362, e-85, 15psi... 592whp
                        " enjoy the show "
                        • getouth
                          • Jan 2010
                          • 3343
                          #852
                          17x8-9 BBS LM
                          FEEDBACK:
                          http://www.r3vlimited.com/board/showthread.php?t=316212
                          BMWCCA #398608
                          IG @yagayo38
                          "The Best E30's were built with two camshafts four cylinders and sixteen valves!".
                          • alistairolsen
                            • Jul 2017
                            • 191
                            #853
                            Can you tell me what offsets you used and if there were any clearance issues?
                            Thanks
                            • roznic
                              • Mar 2013
                              • 2879
                              #854
                              She's in the worksssss...
                              • e30m3s54turbo
                                • Jun 2010
                                • 3290
                                #855
                                Thanks
                                The rear Hartge rear wheels a 17x8.5 et 27 with a 255x40x17.
                                I have not rolled finders.
