Happy to share that I'm the proud owner of Willy's old black car and I look forward to contributing to the community over time. She's a '90 325is set up for HDPE & AutoX while able to handle DD duties.
Thanks for being an amazing resource.
Here's the skinny:
Cosmetic and Exterior:
BMW E30 IS lip spoiler
BMW E30 IS trunk spoiler
BMW Grills
All Driving/ Parking Light housings and bulbs Red and Amber
Ebay Fog lenses
After Market HID kit (Used from Ebay, but good quality)
Depo Euro Smilies
Bosch Wipers
Hirschman antenna with body grommet
BMW rubber gas filler gasket
BMW rear bumper trim
BMW Evo front bumper seal (modified to fit standard E30 plastic bumper)
BMW door lock rosettes
BMW two piece sun roof seal
BMW door, trunk and hood seals
BMW Roundels front and rear
Drive Train:
UUC Race Shift lever
UUC DSSR weighted selector rod
BMW selector seal
BMW transmission output seal
BMW shifter carrier bushings and mount (rear)
BMW Reverse switch and wiring
AKG delrin carrier bushings (Front)
AKG polyurethane transmission mounts
AKG polyurethane motor mounts
Febi Bilstein Guibo w/ new hardware
BMW Drive shaft centering bushing
BMW driveshaft center bearing
USED 4:10 Rear differential refreshed
BMW diff input and output seals
BMW rearCV joints re-packed and boots replaced
FAG rear wheel bearings
BMW Front Wheel bearings
Redlne MTL transmission
Redline 75/90 rear differential
Sumitomo HTR 195/60/14 tires on factory Basketweaves
Suspension and Steering:
Bilstein Sport Shocks Front and Rear
H&R Race Springs
BMW spring pads
ST Sway bars front and rear
Turner Motorsports welded and mounted sway reinforcements front and rear
BMW sway links front and rear
BMW low pressure power steering hoses with crush washers
BMW power steering reservoir
Tie Rods and boots
Meyle Control Arms
Tree House Racing Eyeball control arm bushings
Racing Dynamics Tower bars Front and Rear
BMW Z3 rear shock reinforcements
Engine and Exhaust:
Contitech timing belt and pulley (101K)
Cam seals
Crank seal
Lower timing cover gasket
Oil pan gasket
All hoses and clamps
BMW Thermostat housing
All belts
All cooling system gaskets and seals
BMW blue coolant
Bosch Distributor cap
Bosch rotor
BAV Auto red ignition wires
Bosch Plugs
Bosch 19lb fuel injectors
Black powder coat valve cover (very nice!)
Black powder coat intake
BMW intake gaskets
BAV auto performance air intake with K&N filter
BMP Supersprint twin tip performance exhaust
BAV Auto Catalytic converter
Exhaust system has all new hangars and hardware
Exhaust manifolds have been stripped and high temp coated
Exhaust manifold gaskets
Brakes and Clutch:
Hawk HPS Plus pads
Brembo Drilled rotors (all 4 corners)
UUC stainless brake lines
R3V stainless clutch line
BMW clutch slave cylinder
BMW/ Girling calipers stripped, blasted and painted high temp red
Calipers rebuilt with all new rubber seals and bushings
Castrol high performance brake fluid, clean and fresh
Interior and Misc:
BMW M Tech 2 Alcantara wrapped 370MM steering wheel (bought from German Ebay)
UUC weighted shift knob with motorsport insert
Wheel Skins leather shift boot
Used E30 M3 leather Ebrake boot
Alpine CD player (Used Older model )
BMW window switches
BAV Auto center console gauge cluster with Oil temp, Oil pressure and Volts.
Here's the skinny:
BMW Grills
Ebay Fog lenses
Depo Euro Smilies
Bosch Wipers
Drive Train:
BMW selector seal
H&R Race Springs
BMW spring pads
Tie Rods and boots
Meyle Control Arms
Engine and Exhaust:
Cam seals
Crank seal
Oil pan gasket
All belts
BMW blue coolant
Bosch rotor
Bosch Plugs
BMW intake gaskets
Brakes and Clutch:
Hawk HPS Plus pads
Interior and Misc:
BMW window switches
