Oh hey guys.
  • Danny
    • 14216
    #376
    The two wires in the first picture are from the fusebox, not the harness, grounds still you think?
    • Danny
      • 14216
      #377
      And you said two of my pictures go to the starter : |
      • Matt-B
        The Waffler
        • 3856
        #378
        the "heatshrink" peels back. If there coming from it, then id assume there power.
        yea sorry. Kind of hard to tell in pics. I assume its dark, Starter is 3 wires. an the studs on start are different sizes. so is those 3 loops are small medium big so to speak. then that would be starter.
        starter has a big power, small one, and ground?
        • Danny
          • 14216
          #379
          But from searching I gathered I have to put both e36 starter wires on one pole, truthfully I'm waiting for FredK or someone with 24v swap experience to chime in.
          • Matt-B
            The Waffler
            • 3856
            #380
            yea sorry Im not more helpful.
              • 37828
              #381
              Those 2 wires go to the positive battery terminal on the firewall. You need to steal it from your E30 shit most likely. That positive terminal they connect to goes to the starter.
              Classic BMW Specialists
              Grover Beach, CA
              www.BimmerHeads.com
                • 37828
                #382
                One fusebox wire goes on the a 10mm head bolt on the terminal, one goes to a 8mm head bolt on the terminal.
                Grover Beach, CA
                www.BimmerHeads.com
                • Danny
                  • 14216
                  #383
                  10-4, any more insight Matt?
                  • FredK
                    • 14759
                    #384
                    The problem is, these pictures don't show where the wires are coming from.
                    1st picture, MR 325 is right, if they're coming from the fusebox, they are power wires. Make life easy. Use an M20 starter cable and attach these fusebox power leads to the starter cable lug.
                    2nd picture most likely shows the diagnostic connector, 2 power wires, and a ground. Matt-B is mostly right. There are two wires paired with the diagnostic connector. One is power. One is ground. There's another fatter power wire that's pictured there, that's probably the E36 starter / fusebox power cable. Use the E30 cable. Remove the E36 starter cable.
                    3rd picture shows the positive power block. There's a thin wire paired with the main battery cable (fused power) that goes to the trunk. This attaches to the very top post and is sandwiched together with the small power wire on the diagnostic connector branch. There are NO GROUNDS here. The bottom two posts are there SOLELY to secure the cable to the firewall, and should NOT be used for any other purpose. As Matt-B said, if you're looking for a ground, use the M6 body nut that's at the front edge of the battery tray.
                    4th picture shows the E36 starter cable and E36 fusebox power. The E36 powers the fusebox in a different fashion than the E30. In an E36, there's a fat power lug that splits into two cables inside the wiring harness box. Just remove the E36 power cable and use an E30 one. Seriously.
                    And the 5th picture, as lifeiskaos said, is the backup sensor plug. Ignore it.
                    You probably already know this, but don't forget to attach the engine ground strap from the passenger engine mount arm directly to the ground post on the passenger frame rail.
                    • gregslow318i
                      • Sep 2007
                      • 1918
                      #385
                      1st pic main pwr feed for the fuse box both wires go to the +12v junction box on the pas side
                      2nd 1 is main motor ground (pull back heat shrink should be brown and a brown w/orng trace (2 wires total)
                      other is main +12v for the motor harness, and the other is a +12v for the e36 fuse box (remove this)
                      3rd no this is the main +12v junction box and is not a ground location, the wire with the ring term is +12v for the cabin accessory
                      4th once again small red lead is the other end from the e36 fuse box feed (see pic 2) the other big wire is the main starter motor +12v feed (remove it and use the m20 feed in place of it, as it works better and fits the junction box (see pic 3)
                      5th that is the e36 reverse light plug (don't need it)
                      looking for a e30m50 swap harness adapter pm me $150 shipped
                      email nitroman12@gmail.com
                      • Wh33lhop
                        • 11705
                        #386
                        Got my shifter arm from Wh33lhop.
                        I really think I outdid myself here.
                        paint sucks
                        • Danny
                          • 14216
                          #387
                          Lets say I don't have an m20 starter cable, what other options do I have?
                          Everything aside ffrom the first picture is coming off the e36 harness. This is coming off the passenger side of the harness. Where does the power that ISN'T the starter cable connect to? The distribution block on the firewall?
                          10-4, so nothing else gets connected there aside from the wire in the picture.
                          And the e30 power cables are the two pictured in the first picture correct?
                          Okay dokay.
                          Right on, thanks for the reminder.
                          And so they both get attached to the top bolt for power yes?
                          The thinner one is for the fuse box? As you said two quotes down?
                          Okay sounds good.
                          And again, lets say I don't have an M20 stater cable, any alternatives?
                          Awesome.
                          • jackbenny
                            • 414
                            #388
                            I'm in the same boat Danny. I don't want to use my M42 harness because I'd like to keep it intact for the swap into my E21. So I have the E36 starter cable in right now. I wanted to clip off the end and put the same termination the M20 has to go on the power lug, but I haven't found any I like.
                            The M20 starter cable is around 60 bucks from a place like pelicanparts. I didn't check with Blunt but I have a feeling it will still be more than I want to spend, especially since all the parts are essentially there.
                            -Josh
                            Check out my build thread...
                            http://www.r3vlimited.com/board/showthread.php?t=131055
                            Need parts? Support the community!
                            http://www.gutenparts.com
                            http://www.blunttech.com
                            • gregslow318i
                              • Sep 2007
                              • 1918
                              #389
                              post a wtb add for a m20 starter cable as it really is the best fit....
                              or buy a new m20 starter cable as it is the best fit
                              if you make something its going to have to accommodate the the battery post terminal on the pass side junction box along with other power wires
                              • Danny
                                • 14216
                                #390
                                I'm using an e36 starter if matters.
