moving up at 16
  • trackjunkie21
    • Jan 2010
    • 3962
    #196
    Originally posted by jasonsnoddy
    That pic isn't smoled, just all red. Alsoim perfectly happy with my vogtland springs and e90 drop hats. Gets the job done and won't break the bank
    Those are the springs I'm saving for. The Vogtlands. Since it's a DD no need in having a suspension that will break my kidneys.
    Originally posted by Wh33lhop
    VANOS: sometimes you just need to go full retard.
    • freeride53
      • 11972
      #197
      yee. how much is the vogtland drop?
      1983 Peugeot 505 STI
      1992 Volvo 240 Wagon
      • trackjunkie21
        • Jan 2010
        • 3962
        #198
        It's about 1.6 inches front and 1.3 rear iirc.
        • freeride53
          • 11972
          #199
          Nice. That's pretty much the same as mine, but my springs aren't new. I'm gonna run it w/o the pads in the rear, and hopefully my e90 drop hats will arrive in the next few days.
          • jasonsnoddy
            • 1900
            #200
            this is what it looks like on 55's
            and you will definately want to get the drop hats, as well as take out the spring pads and anything else that will get you lower in the front haha
            Originally posted by stewie30luvr
            ooo cause i was fixing my chain tensioner and there was a black widow on the radiator so i killed it
            Originally posted by JakeP
            with a coathanger
            • dannyyisntt
              • 3141
              #201
              the car is lookin good man
              • trackjunkie21
                • Jan 2010
                • 3962
                #202
                Perfect ride height for a dd. I will probably take out the spring pads, don't know about the drop hats, NY roads are a real killer.
                Thanks
                • trackjunkie21
                  • Jan 2010
                  • 3962
                  #203
                  Found some blacked out kidneys, Thought I would give them a try. I like them alot and the only problem I have, is that the trim around it is a bit lighter in color. Would you guys recommend me to plastidip the grills? or just get some trim paint?
                  Also this is kinda bothering me. In the actual kidney is like a block off plate, like the one on the non a/c models. Would this be a problem? I rarely use A/C anyway, and I am probably going to dump it.
                  • Cabriolet
                    • 9620
                    #204
                    you can buy plastic spray paint made by krylon
                    http://www.krylon.com/products/fusion_for_plastic/ worked well for me
                    Much wow
                    I hate 4 doors
                    • trackjunkie21
                      • Jan 2010
                      • 3962
                      #205
                      when I apply this I just give it about 3-4 light coats, correct?
                      • freeride53
                        • 11972
                        #206
                        yeah, pretty easy process. krylon works great, so does duplicolor. Did mine a few months ago. works great on trim, as well as grilles.
                        • trackjunkie21
                          • Jan 2010
                          • 3962
                          #207
                          Alright, works for me, I'll get on it. I don't like how it's all a different color. So their are three different blacks. Should I go with satin or flat?
                          • davem
                            • Jun 2010
                            • 705
                            #208
                            Did you find bolts in your oil pan? What is the mileage of the car again (don't want to read the whole thread)?
                            • trackjunkie21
                              • Jan 2010
                              • 3962
                              #209
                              134k miles. I didn't find any bolts, just some that were loose.
                              • freeride53
                                • 11972
                                #210
                                satin mayne. I was contemplating doing an M-stripe down, like this Armenian dude with a alpina e30 m3 near my house, but i didn't feel like buying the extra paint. :pimp:
