This is my BMW E30, build from E30 M40B18 1991 DiamantSchwarz Metallic to M42B18 SterlingSilber Metallic
Engine
- M42 B18 1990
- 16v DOHC Direct Ignition
- Port polished head
- Crankshaft balanced
- Larger throttle body
- Custom Exhaust Manifold
- 4,34 open differential
- K&N Replacement Air Filter
- M40 Flywheel conversion
- ECU remapp by Mark D’Sylva, 95 RON
- Vitesse Motorsport clutch stop
- 2" exhaust pipe
- Twin pipe sport muffler
- Z3 1.9 short shift P/N : 25117527252
Suspension
- Eibach Pro-Kit p/n : 2021-140
- Bilstein Yellow Sport, fr : P36-0335 rr : B36-2027
- M-Technic 19mm anti roll bar kit
- E30 M3 control arm bushing centered
- Alutec Strut Brace front
- Sparco Strut Brace rear
- Rogue Engineering rear guide support
- AC Schnitzer type I wheel 16x7,5
- Achilles ATR Sport 205/50/16
Brake
- Stock E30 325i conversion
- OEM BMW disc front (ventilated)
- OEM BMW disc rear
- Ate Brake Disc front + rear
- Ate Brake Pads front + rear
- Ate Brake fluid
Interior
- Recaro SR-3
- AC Schnitzer Steering Wheel
- AC Schnitzer Shift Knob
- AC Schnitzer pedals
- OEM BMW Mirror with Map Lights
- Euro Cluster conversion in MPH
- Black kidney grille
Exterior
- Spray in Sterling Silver Metallic (OEM BMW E30) – Spies Hecker
- AC Schnitzer body kit
- AC Schnitzer grille badge
- AC Schnitzer trunk badge
- Hella Smoke head lamp
- MHW Germany smoke tail lamp
- Foha heckspoilerl
- OEM BMW Wiper head lamp
- E30 325i Oil Cooler Grille
- Clear side indicator
- Smoke front indicator
- HID 4500K -- headlamp
- GE Megalight+ -- H1 beam
- GE H3 All Season -- foglamp
- now with AC Schnitzer decal (copy)
ICE
- Nakamichi TD-45z
- Nakamichi MF-51 changer
- Fusion 4ch power amp
- Rodek split speaker front
- Hart 6,5" 2way rear speaker
and the pics....
Worskshop :
- Paint and body repair : Perfect Auto Body
- Engine, Brake, Suspension set up / installation : ALTA Racing
- Custom Exhaust Manifold : SR Motorsport
Engine
- M42 B18 1990
- 2" exhaust pipe
Suspension
Brake
- OEM BMW disc rear
- Ate Brake fluid
Interior
- Recaro SR-3
Exterior
- Foha heckspoilerl
ICE
- Nakamichi TD-45z
and the pics....
Worskshop :
