This is going to be very disorganized in the beginning mainly because its taken from bimmerforums and its hard to weed out the essence of the thread itself, so I just took a bunch of it and pasted it here. Hopefully you guys/girl(i think its only e30grl) can help me out:).
I joined bimmerforums way back in 09(2 years, big woop) and finally decided to make a r3v account after lurking for forever. On to the thread!
This is where it starts
Well i went through quite the adventure to get this. It started out as a $300 ad posted on here which i quickly pursued. It happened to be in Tallahassee, FLorida, whereas i was in South FLorids...But luckily i know some people that know some people
So I ended up bringing it to Micanopy and left it there for a month with some close friends. Then we attemped to bring it all the way home and 10 miles out, the right rear wheel hub is overheating. So we bring it back and it sits for even longer. Then eventually we get out friend with a full bed trailer to tow it down and it arrives in all of its glory. Now i have 2 e30s, one vert and one coupe
So far i have managed to deal with some electrical problems
yes, thats what happened when i touched the thing, it fell apart! Hence my starting/accesories problems...
I have figured out part of the problem why the rear wheels drag..
If you look between the hub and caliper you can see part of the brake pad that broke off and wedged itself in there, creating a doublestuffed oreo with the other half of the pad
But onto the actual pictures of the car!
the trashbag was there because of the ignition switch problem not allowing me to close the window
front end removed for tow bar setup. Yes it has the bumper and sweet IS valance
My baller wood hood shock
this is to get rid of the rust in the rear, I think JB weld would hold it
and would somebody please tell me what radio this is? Yes it is BMW
And this all came with ton of spare parts!
*flame suit on*
UPDATE
Well now that the car is turning over and getting spark, i decided to see whats going on with fuel so i disconnected the fuel line going to the fuel rail and it was bone dry
SO then I go back to the fuel filter and disconnect a ball thingy next to it, that had fuel, or so i thought, it just turned out to be old rancid fuel. So next the filter came off and dry again!. so i pointed the line going to the filter into a bucket and tried to start the car. Im not an idiot, i just wanted to see if fuel would come out, but sadly, nothing. Yes there is fuel in the tank, i put in 5 gallons last night.
So does anybody have an idea of what might be going on? and might i say that when i got the car, the lower back seat was resting in place, so i assume this isnt a new problem...AM i sh*t out of luck and its the fuel filter or is there some magical relay that seems to go out and cause this?
And what do i do about the radio? anybody know what it is?
UPDATE
ok, so i managed to squeeze out the radio, man that thing was in there tight! I wasnt able to get any pictures because its too dark outside but it looks like two yellow wires on the harness on the radio are disconnected, maybe causing my problems?
Heres what it said on the stamp/sticker on the radio:
BMW model CM5804
FCC IC :/\ 269ZUA027
Made in Japan
yada, yada, yada about amperage and stuff
Alpine Electronics Inc.
then on a metal plate on the rear it said:
40237214 A
anybody have an idea of what this is?
Another Update
Quote:
Originally Posted by djb2
Which radio?
The connectors should work, if you get the part of the harness that substitutes for the external fader control.
CM5804
Early e30 radio built by Alpine Electronics
AM/FM/Cassette, Dolby, no weather band or anti-theft
Bass and Treble sliders under volume knob on the left
Center cassette door over the display.
Mechanical FF and rewind buttons to left of door
One row of 5 preset buttons under the display
Function buttons, including Dolby button, on the right.
Yellow and white power pigtail w/ 2 pin Molex connector, antenna pigtail
This ones mine ^^^^
CM5905 or CM5907
Common on e30 models, built by Alpine Electronics
CM5907 had weather band
Single knob (for volume), Sliders for treble and bass
Two rows of five buttons
Two speaker outputs, left and right, used with fader control on dash
Premium system had the fader feed the rear amplifier
Yellow and white power pigtail w/ 2 pin Molex connector, others plug in
CM5908 Alpine w/ infrared slot, 89-93 e30
Four speaker outputs, no fader control on dash.
White/brown and Blue/brown second pigtail.
Cable 1-388-934 converts rear speaker outputs to 8 pin fader control connector
CD changer control with 13 pin round DIN socket in rear
CD control socket has 3x4 array, plus 1 opposite key
Works with TR1000, TR1600 and TR1008 (6, 6 and 12 disc) changers
BMW-specific data cable, NLA
Pioneer (KE83ZBM) with the +/- (mode) in lower right corner
Single volume knob on left side, two paddle levers
Weather band button, six presets in two rows
CD changer control
reported on 4/89 production 325i
*flame suit on*
UPDATE
UPDATE
BMW model CM5804
Made in Japan
40237214 A
Another Update
Which radio?
CM5804
This ones mine ^^^^
CM5905 or CM5907
CD changer control
