Sweet thanks appreciate the comments! I'm hoping to have the Alfa with the new motor in by them as well. Hopefully I cant figure out what is wrong with my e30. I need to get it running.
85 325e introduction and start of my build thread
Nice cars ian
I help out occasionally at richards shop and scored some m5 parts of one of the guys at unique, he has a e39 5 series of some sort.
I have seen your alpha driving around town.
a friend of mine developed a maf conversion for the alpha
he has one exactly like yours
milano
red ext
recaro interior
here is his website
Ron Jones is a mechanical engineer with diversified experience in automotive design and product development.
that might be cool to have on your turbo motor.Comment
LOL you paid way to much for that car! got my 85 ETA for 400$Comment
Okay
So got the car running but ran into a problem.
I got a m42 radiator the one with expansion tank on the side... but from the junk yard.
It seemed to be in good condition but now I'm thinking other wise.
So basically the car is "over heating". The thermostat I thought wasn't opening but I tested it and it opened sooner then the new one I bought. So if any one has any insight on ideas let me know. The head and gasket are fine. The oil isn't milky and I did a leak down test.
What radiators are you guys running on your 2.7's?
I just wanted the clean bay look but as of now I just want to drive it.sigpic-Thanks warrenComment
m42 radiators are tricky to bleed the coolant system
one trick is drill a tiny hole in the thermostat
the better trick is to run the heater on 4 with all the vents open
and raise the driver side front end with a jack to get all of the air pockets out.
the best is to do all of the above.Comment
ohhh.... :-(
okay I will try that I just don't like jacking the car up when its running I feel like I'm going to starve the motor of oil. I did have the heater open on 4 with the 3 vents open but its still blowing cold air...? Guess 'll try drilling a hole as well.
I just am concerned on keep on "heating it up"sigpic-Thanks warrenComment
okay so here is the deal.
I feel like my radiator I got isn't good. Though I put a hose in one end and it came out in a consistent flow on the other side. Though I am confused. When i fill up the expansion tank on the side of the radiator it just go into the small 1/2" line at the bottom. I know that the radiator won't fill up until the thermostat is open, so I just took it out. The problem is it didn't start pulling in the coolant the level stayed the same. I'm not sure if the water pump just isn't working.... which is what I'm leaning towards. Does any one have any experience with the m42 radiators on m20's? I'm confused and just want to drive the car.sigpic-Thanks warrenComment
The water pump works fine, it's the mechanic that's the problem.Comment
Like the color!My previous build (currently E30-less)
http://www.r3vlimited.com/board/showthread.php?t=170390
A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsessionComment
nice. looks like you got a good set of plans for it.-FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
-The Beauty in the Tragedy-
MECHANIC SMASH!!- (you all know you do it)
Got Drop?? ;-)
Originally posted by JinormusJBut of course
E30s are know to be notoriously really really really ridiculously good lookingComment
