Now back to the cycle of tarbo, then ref then removal, then LSx, then blower.
Danny's 4door Calypso 24v car
You like that 13lb wheel? My buddy has the lighter one and he says it's a little much, but I think he may have gone for the 8.5lb one? That's a common one, right?
Anyway that bimmerworld intake + larger MAF sounds so awesome that's almost worth it alone...Originally posted by z31maniacI just hate everyone.
No need for discretion.
Originally posted by 87e30 View PostYou like that 13lb wheel? My buddy has the lighter one and he says it's a little much, but I think he may have gone for the 8.5lb one? That's a common one, right?
Its a nice flywheel. I have A/C in my car and it very seldom dies when coming to a stop with it on. Otherwise the idle is just like stock. I'm thinking of going back to the bigger maf and boot. Too bad I sold it to RobertK.
Okay so two issues with my car right now. My unloader relays do not work. I currently have k5 and k7 jumpered with a wire to get the windows and aux fan/blower motor to work. Problem is they are constantly hot. The battery will drain. I saw a post by Nando that I can ground pin 15 of the c101 to bypass the unloader relays. He won't answer my PM. Can anyone else verify?
Second issue is the car has absolutely no midrange. I have had the VANOS unit replaced with a Dr. Vanos unit by RyanGMW. Still have no midrange. the car is gutless until about 4500 rpms. I'm leaning toward VANOS solenoid but I have no check engine light. Kyle (Surebimmer) suggested replacing coils. Thoughts?
Easy enough to see i it's coils. Remove the connectors to them one by one with the engine running. If you hear the engine note change, the coil is good. If there is not change, there is a problem with that coil, boot or plug. Or something else with the cylinder...
Good luck!Originally posted by LJ851kingston is the play by play announcer for this thread.
Originally posted by unloadedak#teamross
As I mentioned that's not what my car was doing when a couple coils went bad... but then cars often show multiple kinds of symptoms.
Drove my friends car with the ford injectors, larger MAF, OBD1 IM, and 8.5lb flywheel... I don't know how these cars left the factory any other way. Really wakes them up. :)Originally posted by z31maniacI just hate everyone.
