Dyno Results 17psi 4k redline
  • matt325is
    • 409
    Well, today I went to the dyno day here in Olympia, WA, it had quite a turnout, mostly imports, a few American muscle... Anyway, strapped my car on for $35 which is really cheap, and got a couple runs.
    The first run I had wheelspin. They had to strap it down a little more after that, sounds cool though heh.
    The second run, I got a good run, but I think my clutch is slipping, and only recorded power for 3400rpm (on the sheet, my MS datalog recorded to 4krpm), which could be why you see the blue lines, because it retraced over itself. Anyway, it was a good run!
    RESULTS AT 3400RPM @ 17.6psi (1.22 bar) (due to injector duty cycle being around 100%)
    237WHP -> 285bhp
    381WTQ -> 459tq
    VIDEO
    Problems: Found out my rear sway bar end link is broken. My clutch is also slipping, so I'm planning on the IE disk coupled with the centerforce pressure plate (should be strong enough.. heh).
    Also getting my 83lb/hr injectors this week.
    matt
  • nameisbradgreen
    • 270
    wow nice numbers
    im jealous :(
    • bmwe3
      • 118
      wow 381ft/lbs thats gotta be fun
      ever try spec clutch i had a stage 3 in my car and ran 15psi no slipping i think there $384+ shipping new pilot bearing,release bearing,disc,pressure plate.
      • M42Technik
        • 9781
        That is scary.
        Reminiscing...
        • NORCAL/E30
          • Dec 2004
          • 258
          I need boost. :( Or another 400hp camaro. :twisted: What do you think your car will do in the quarter mile?
          ABE
          • var1ant
            • Apr 2005
            • 509
            Holy shit, What is that thing? If it by some ungodly chance happens to be a m20 why only a 4k redline?
            edit: went through your site for about 10 minutes and I have to say you frighten me with what you have done to your m20...
            '87 alpine white 325is
            • Stu Mc
              • 4083
              Holy smokes Matt 8)
              • f u z z
                • 1600
                mmm torque. badass man.
                • Mystikal
                  Wheel Fitment Expert
                  • 9602
                  Re: Dyno Results 17psi 4k redline
                  Originally posted by matt325is
                  83lb/hr injectors
                  Christ.
                  That car is downright scary. :twisted:
                  • Il Duce
                    Non-Mod M42 Modder
                    • 5040
                    good lord matt! keep up the good work. that car scares me!
                    btw, do you have a link to that collage vid you posted a while ago? i seemed to have deleted it from my computer :(
                    dont ever get rid of that car
                    • Hatchman
                      • Mar 2005
                      • 1425
                      Thats like 3 of my car put together nice freaking numbers
                      • randomtask37
                        • 3154
                        your powerplant is just sick... thats all there is to it.
                        98 M3/4/5
                        • golde30
                          • 11464
                          those torque numbers are unholy...when i look at those numbers i keep seeing that video of the guy with the black turbo m20 who was spinning the tires like mad every time he hit the gas :twisted: . that is just badass. u need to get some 16x9 on the back to hook up all that torque! 8)
                          IG: @Baye30
                          • 88325isboy
                            • Mar 2004
                            • 1058
                            man that is crazy numbers good job! :up:
                            '87 325 (Track Rat)
                            '04 C5500 Wrecker (Work)
                            '94 525i (Daily)
                            '90 325i (R.I.P)
                            H&R Race, Racing Dynamics Sway Bars, Tree House CAB's, Sparco Strut Bars and more.
                            • m42technic
                              • 1056
                              Thats some rowdy torque. :twisted:
                              James Peacock
                              WWFSMD?
