Intro and Saving a Sedan resto. pic heavy
  • spyde25
    • 157
    Well it is about time i introduce myself and my new E30. My name is Evan and I like many others Love BMWs. Previous lineup includes E36, 840ci, 740i sport black on black. I choose to go down the E30 route because i wanted a four door i could tinker on that was fun and sexy.
    Previous lineup
    I also wanted to create this thread as journal and history of my E30
    But enough about me. I picked up a 1988 325i sedan 5 speed with sunroof and a broken T-belt for $700 thanksgiving 2010. It had 225,000 on the inop ODO, reviewed the records that he had and it worked until late 2004. He only put about 8000 a year on it.The PO was a high school student who used to commute 2 miles to high school. The timing belt broke when he was getting the mail in front of his house, he towed into his yard and it sat there tell i picked it up. I wanted to buy a E30 in this shape so i could go thru everything with new and know exactly where and what the condition the car was in.
    Here it is when i picked it up, good paint and a little cancer under the license plate.
    First order of business was going shopping.
    Removed the head and sent out for check and rebuild. Head was good just 2 bent bent valves and 2 broken rockers. replaced rockers and put in all new valves.
    While the head was out i replaced the following so i would have a good starting point and reduce the down time for troubleshooting in the future.
    Timing belt
    Tensioner
    Water pump
    Thermostat
    All belts
    Cooling hoses
    Induction elbow and corresponding hoses
    Air filter
    oil and filter
    Spark plugs
    Plug wire set
    Coil
    rotor
    Distributor
    Coolant
    Tranny fluid
    Diff fluid (this weekend)
    Fuel Filter
    ECU upgrade and a 91 chip
    Swapped out injectors from my E36 that was just totaled (rage)
    On to the Pics
    Right off the bat i thought i was in trouble when i pulled the lever to pop the hood and it broke in my hand.
    My little helper, i had to go get her own tool set as mine started to disappear
    The PO live in the country on a dirt road so everything was dirty.
    Cleaning time
    I used aircraft stripper i had laying around to clean the cosmolean off
    All back together
    Moment of truth
    Rolled it out of the garage and had the wife on duty with a fire extinguisher and bucket of water just in case.
    Cranked it over....for about 10 seconds. nothing.
    Sat there for a second and then started to curse at myself. :hitler:
    I then went and put some gas in it. Fired right up. I then drove it like i stole it for a little bit with the hood off. Checked for leaks periodically, once everything was snugged up and the ECU learned its range it was running good.
    I now have a good running E30, Phase 1 complete.
    I now have bugs to work out that any 20 some year old car has. Brake light, flashing check light, ABS light, water leaks ect. Bug chasing will always be there as long as i own the E30 so for now i call Phase 2 complete
    I now turned to some cosmetics.
    Front valance and fogs were broken and no lip was to be found. And Cancer :-x
    Rebuilt the cluster and set the mileage appropriately, also put some cluster rings in for ascetics.
    I also went ahead and tucked my bumpers while i was in there. Very easy.
    Put on a new shift boot (thanks Matt-B) and addressed the cancer and covered with Euro plate holder
    Took off the bottle caps and replaced with some 17x7 ADRs
    Phase 3 cosmetics hopes to be wrapped up this weekend. Still need to put on my sport pedals and IS decklid spoiler.
    It is now spring and warm enough for a good wash and wax
    I cleaned the engine first (still need to upload pics of engine) then washed the car. I attacked with a clay bar then another wash. Then came a cleaner wax. About this time the temp began to climb so i didn't get as a good wax job as i wanted to do.
    Before
    After
    Fam all loaded up heading out to the first meet of the year
    Yes i know i need a drop and IS lip. I would have a hard time getting into my driveway if it is dropped. So for know i just replaced the suspension with stock and went thru the front end with the following kit. and brakes were done as well.
    This is my daily driver now so i will not get to extreme with it, just love to tinker on it.
    Phase 4 will be this fall and that will be interior based with a sport seat upgrade and complete interior recovering.
    Phase 5 will be centered around the power plant.
    my 88 325i sedan
  • Schnitzer318is
    • Jan 2008
    • 2057
    Very nice... keep up the good work.
    "A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
    91 318is Turbo Sold
    87 325 Daily driver Sold
    06 4.8is X5
    06 Mtec X3
    05 4.4i X5 Sold
    92 325ic Sold & Re-purchased
    90 325i Sold
    97 328is Sold
    01 323ci Sold
    92 325i Sold
    83 528e Totaled
    98 328i Sold
    93 325i Sold
    • Cabriolet
      • 9620
      hot wife, cute kid, great start on that car. looks good. next needs moar low.
      Much wow
      I hate 4 doors
      • kingston
        • Jun 2010
        • 2669
        Nice seeing the car at Grinder's! Looks great!
        Originally posted by LJ851
        kingston is the play by play announcer for this thread.
        ‘Tis by the grace of God that my cars run!
        Originally posted by unloadedak
        #teamross
        Siobhan's Build Thread - UPDATED!
        • spyde25
          • 157
          You had your hands full that night
          my 88 325i sedan
          • Mrod 91 318IS
            • Jul 2009
            • 72
            Welcome aboard, nice thread and great looking car! Keep us posted with the progress on the car. It needs a little drop :D
            91 318IS :p
            02 330CI ;)
            • kingston
              • Jun 2010
              • 2669
              Yes I did! Gotta get the kids hooked early! I think next time I'll go solo, tho...
              I'm hoping there's another KC meet in May, when I"ll have gotten to do some more work to my car. I think I'm heading to St. Louis for the Deutsch Marques meet. You going by any chance?
              At some point I want to do a little photo shoot w/ our 2 cars!
              #teamross
              • staianoa
                • Jun 2010
                • 14
                Nice work!
                Good to meet you yesterday Evan. It's great to see all of the great work you've put into your e30. I'm sure phase IV and V will be fantastic. Take care and keep posting!
                • 1mz
                  • Jan 2009
                  • 641
                  nicely done!
                  http://l0st0n3.mybrute.com
                  http://l0st-0n3.mybrute.com
                  Work in progress: 1991 318i m50 swap
                  Feedback thread :up:
                  I prefer having a female in the car at all times. They generally smell good, but you do have to put up with that hole in their face.
                  • Butler
                    • Nov 2009
                    • 1613
                    Nice progress. You paint cleaned up pretty good!
                    -Nick
                    Originally posted by 87e30
                    First of all: calm the fuck down; second of all; cool story bro.
                    • trackjunkie21
                      • Jan 2010
                      • 3962
                      Awesome car! Congrats!
                      Originally posted by Wh33lhop
                      VANOS: sometimes you just need to go full retard.
                      • BrewCity11
                        • Mar 2008
                        • 2335
                        I've never asked this on any forums before. In the most sincere and respectable way, can we have more pictures of your wife please??????? (fuck, i feel like a creep even asking. but I did say please)
                        turk@gutenparts.com
                        • PaladinReed
                          • 1524
                          perv
                          Car looks great. Hope I'll catch you at one of the KC meets soon.
                          Late model granitesilber 325i convertible FS:
                          http://www.r3vlimited.com/board/showthread.php?t=293701
                          • spyde25
                            • 157
                            thanks to staianoa i now have my tan leather sport seats. also have a sport lip i need to mount.
                            my 88 325i sedan
                            • spyde25
                              • 157
                              i got her knocked up so i dont have any recent good ones.
                              made a deposit for you in the girlfriend thread
                              my 88 325i sedan
