Ravs "NEW" Old Chromie E30 M30 Supercharged
  • matthugie
    • Mar 2004
    • 1810
    #91
    Subbed. You, sir, are a gentleman and a scholar.
    88 325is - S52 powered
    Originally posted by King Arthur
    We'll not risk another frontal assault, that rabbit's dynamite!
    • e30m3s54turbo
      • Jun 2010
      • 3292
      #92
      I like your project. I am also going to build e30 car with a m30 engine an M88 itbs .
      • Bavarian Performance
        • Dec 2010
        • 39
        #93
        Originally posted by rav320uk
        These turned up today too.
        Adaptors for the ITB's :D
        Where did you get the adaptors from?
        Edit found the answer in your thread. Have you tried fitting them? How was the fitment? Might have to look into this for my m30.
        Great build!!!
        • rav320uk
          • Jun 2004
          • 1337
          #94
          No , haven't test fitted them, but I know they work, as one of the zone guys has the same ITB's on his M30 Turbo car.
          Anyway, can't try them, as i've sent the head away for the valves and valve seats to have 3 angles put on to them, couldn't resist it as I had a very good price quoted to have it done.
          Had the block honed today too, needed doing as there was slight scoring on a few of the bores.
          If you have bought items from me, please leave feedback below.
          If you are a BUYER, Check My Feedback.:up:
          http://www.r3vlimited.com/board/showthread.php?t=183860
          Check out my Euro Build Thread
          http://www.r3vlimited.com/board/showthread.php?t=215557
          • rav320uk
            • Jun 2004
            • 1337
            #95
            Well, only a small update.
            Had a load of parts Soda and media blasted to get rid of all the oil and wax on the parts.
            The ITB's were like this
            To this
            Also, had some head work done in the last few weeks too, thought it would be nice to treat it to a better flow
            Had the seats and vlaves cut to 3 angled finishes.
            Next new seats, cutter pilot installed.
            The first cut at 60* is the bottom cut.
            Followed by a 30* top cut, then the seat cut, both are on a double sided cutter. The seat cut is at 46* the two faces will bed in together within the first moments of the engine being started.
            This is what you end up with after it has been soda blasted, and all the cuts finished.
            A before and after, not alot of difference really as the head had already been scrubbed, but the soda gives it a nice uniform look and doesn't damage the surface of the alloy.
            • Mlarsen
              • 4082
              #96
              I like where this project is going.
              • whodwho
                • Jun 2008
                • 1547
                #97
                Looks good, Neway cutters rock!! I have a setup for 5 angle cuts :)
                My M20 Frankenbuild(s)
                4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
                • rav320uk
                  • Jun 2004
                  • 1337
                  #98
                  I thought that may have been an overkill on mine, plus it was way more than I thought too, so opted for the 3.:p
                  Only a small update to keep you happy. :D
                  Firstly, all new chain guides fitted yesterday,
                  New thrust bearing and shells fitted, dropped the crank in and tightened up the bolts.
                  For some reason, there was quite alot of end float which was a bit baffling, as everything was measured by using a micrometer :? .
                  So off came the crank again, the old thrust bearing installed, and then everything reinstalled again, this was to check the origional end float on the crank, cam to 0.005th :?
                  So, vice versa, new one installed, and for some reason, don't ask, there was reduced crank end float to about 0.002th, so checked and rechecked, phoned a few guys on the Zone to make sure and all is now ok. :D
                  • rav320uk
                    • Jun 2004
                    • 1337
                    #99
                    Had a little time to spare today, so got on with putting the pistons back in.
                    Oil'd up the bores, and put in all the pistons one by one.
                    The block was then turned over, new shells fitted and the rest fitted and torqued up as needed.
                    Decided to take the Oil pump apart and give it a clean before refitting. :D
                    And fitted.
                    • CorvallisBMW
                      Long Schlong Longhammer
                      • 13039
                      #100
                      Looking good!
                      • rav320uk
                        • Jun 2004
                        • 1337
                        #101
                        Thanks. :D
                        Decided now not to build the head up, I think it needs more work, so watch this space.
                        • rav320uk
                          • Jun 2004
                          • 1337
                          #102
                          After pissing around today :crazy: and not doing much this morning, I finally decided to pull the ITB's apart and start to clean and paint them.
                          After a few hours :roll: of freeing up bolts, cleaning faces and general spraying, I ended up from this:-
                          To this:- :D
                          The "Eagled" eyed of you will notice it's not the exact same part, but you get the idea
                          Only 2 more to go
                          • CorvallisBMW
                            • 13039
                            #103
                            They look sexy
                            • rav320uk
                              • Jun 2004
                              • 1337
                              #104
                              Thought i'd strip/paint and rebuild the ITB's ready for when they're needed.
                              • Luis325
                                • 3847
                                #105
                                ME LIKEY!!!
                                got a set of the itb adapters for mine!! Thanks for the info Rav and keep them updates coming!
                                1986 "C2 2.7 Alpina" Sedan
                                1987 325ic Black Vert
