Height difference
  • 808BMW
    • 2910
    Height difference
    I took these pics to try and get my dad to drop his car :P
  • LikeCDoos
    • Jan 2004
    • 2522
    what setup are you running...looks good
    • 808BMW
      • 2910
      GC's
      • LikeCDoos
        • Jan 2004
        • 2522
        cool, how much do you think it dropped the front and back?
        • 808BMW
          • 2910
          About 3 1/4" rear, 3" front
          • AndreNY
            • 632
            are they all the way down in the front and rear
            because the rear looks like 2.5" and the front like 2.7"
            • aaron_silva
              • 1785
              What spring rates are you running?
              • 808BMW
                • 2910
                No, not all the way down.
                I measured the bodyline (not the fender line) between my car and my dad's car.
                • AndreNY
                  • 632
                  the lowest that the GC;s go is 2.7" all around , and i have it at 2.7 cause mine is all the way down in teh front and the back i have a bit more then .5" to go
                  • 808BMW
                    • 2910
                    Maybe I got the short springs or something, I just measured it vs. my dad's car. Same tire size (different brands though) and his is a stock eta, mine is a lowered i. both 4 door, and both measured from the same place.
                    • AndreNY
                      • 632
                      ok but one thing i want to know is by what you are saying your car i salmost 1" lower then mine in the front, and that being the case your oil pan would have to be 2" off the floor, cause mine is 3.25"
                      • 808BMW
                        • 2910
                        Well you should measure your car vs. someone else, because you are 1/2" lower than mine in the front, because my oil pan is 3.75" off the ground last time I measured.
                        • AndreNY
                          • 632
                          ok so that being the case your car is lowered 2" in the front, cause u got 14"s and im on 16"s
                          • 808BMW
                            • 2910
                            We all know your tire size is off :P But your overall tire size isn't the same as stock?
                            • 808BMW
                              • 2910
                              forgot to answer this :P
                              375f/475r
