A formal introduction to "Crunchy Bleach"
  • orcgrinder
    • 107
    Engine:
    -Recently rebuilt 2.5 "i" motor
    -ARP2000 head studs
    -MLS oversized head gasket to lower compression
    -New over-sized Mahle pistons and rings
    -Schrick turbo cam
    -BMP adjustable cam gear
    -Ebay top mount turbo manifold, which Chris rewelded for strength and reliability
    -Garrett T3 60-1 journal bearing turbo: A/R 60, 0.63 exhaust housing
    -44mm v-banded waste gate
    -HKS blow off valve
    -38# Lucas injectors
    -eBay intercooler
    -Intercooler piping: 2.5" hot side, 2.75" cold side
    -German Engineering M20 silicone intake tube
    -German Engineering rebuilt and shaved throttle body, with flipped butterfly and m50 throttle position sensor
    -German Engineering built and fully tuned Megasquirt stand alone ECU: Microsquirt daughterboard and DIY PNP
    -Castro's custom 2 piece, fiberglass intake box - Turbo Version
    -3" custom, mandrel bent downpipe
    -3" custom, mandrel bent oval turbo back exhaust
    -Custom Dr. Pepper 6-pack oil catch can
    -Getrag 260 trans
    -13 lb lightened flywheel
    -Gripforce stage 2 clutch and pressure plate
    A big thanks to Nigel (einstein57) from German Engineering for his awesome products, and for building and fine tuning the Megasquirt system!
    Suspension:
    -Ground Control coilovers
    -Front adjustable Konis (shortened struts)
    -Rear custom shocks with German Engineering extended shock mounts
    -Ireland Engineering sway bars (22' front 19' back)
    -Fully reinforced subframe by Castro Motorsport
    -Vorschlag camber plates
    -95' M3 rack and pinion
    -M3 sway link conversion
    -All polyurethane bushings
    Rolling:
    -ESM 002 16x9
    -Falken azenis 215/45/16
    -Stainless steel brake lines
    Interior:
    -Gutted and tar free
    -NRG steering wheel
    -NRG quick release
    -Momo hub
    -NRG fixed seats
    -Schroth harnesses
    -Castro Motorsport short shifter
    -"Custom" dash
    -BMWpedals.com pedals with custom dead pedal
    -AEM analog boost and afr gauges in German Engineering cluster
    None of this would have been possible if it wasn't for Chris and Castro Motorsport's open minded approach to everything.
    Hands down the most sincere and talented mechanic/fabricator out there.
    Castro's Smog and Repair 818-765-3606
    All pics by Joey Ready (joeyready.com)
    85' e backSTABBATH
    Need a good mechanic/fabricator/performance shop in SoCal?
    http://www.r3vlimited.com/board/showthread.php?t=155404
    Castro Motorsport
    12600 Sherman Way, Unit C
    North Hollywood, CA 91605
    818-765-3606
  • masduro
    • Aug 2011
    • 221
    Bong hits with bleach instead of water. Rad car.
    • Pantless Spency
      It's McRib time!!!
      • Feb 2011
      • 7283
      i just came, until i saw the blinkeye mirror,
      #getdatshitoutahere :P
      • krooks
        • Jul 2010
        • 239
        nice tires!
        1991 E34 M5
        • widebodye30
          • Jan 2006
          • 3407
          Nice work!
          www.esmwheels.com
          www.dtmfiberwerkz.com
          Toll Free: 800.729.5450
          Local: 818.341.9903
          • FunfGan
            • Jan 2011
            • 4958
            Yes. This day gets better.
            Go here be happy!
            Ratchet Garage e30 V8 build.
            • !AjHoWzA!
              • Jan 2010
              • 1140
              Cool looking car man. Like it
              '91 318is
              • Mlarsen
                • 4082
                I like this a lot.
                • CW325
                  • Jul 2011
                  • 1434
                  very cool
                  • csermonet47
                    • Jul 2009
                    • 937
                    Too rad. I really love this thing. Engine bay looks amazing!
                    Are Three Vee
                    Dad Spec
                    • ZM Blue Devil
                      • Dec 2006
                      • 13836
                      saw it in person and sat in it... Loved it then love it more now.
                      Levent
                      %20levent@gutenparts.com
                      Ladies:
                      • george graves
                        • 19997
                        cause racecar! ;)
                        Originally posted by Matt-B
                        • 89is
                          • Dec 2010
                          • 224
                          Love at first sight, fantastic work.
                          Originally posted by Wh33lhop
                          If you actually stay within your budget, you are not a true car enthusiast. True story.
                          • Ayman
                            • Apr 2011
                            • 4190
                            This is one of those uniquely done cars without overkill :up:
                            Originally posted by yert315
                            Your mother is plug n play
                            • SimplyDope
                              • 1335
                              For the most part ;)
                              Car looks good. Lovin' the wheels.
