My official restore/build "87 325E 4dr/5spd
  • IronicBenzTech
    • Nov 2011
    • 46
    So I have already introduced my newly acquired 1987 325E.. and by recommendation by you guys I am starting by build thread. As of now its more of a "Get everything straightened out" thread.
    This is the Night I got it $1600 later
    [ATTACH]49431[/ATTACH]
    Pretty Nice Interior for a 24 Year Old Car
    [ATTACH]49432[/ATTACH]
    LETS START WRENCHIN' !!!!!
    [ATTACH]49435[/ATTACH]
    Custom Matching Babyseat in the back (lol)**
    [ATTACH]49434[/ATTACH]
    So Far what I have done is purely Maintenance, safety, or function repairs
    I have until the end of December to Smog this puppy!!
    Heres what i got so far
    1. Valve Adjustment
    2. Spark Plugs Replacement
    3. Fuel Filter Replacement
    4. Oil Change (I'll post pics of the nice surprise I got and repair)
    5. Blower Motor Resistor Replacement
    6. Engine Air Filter Replacement
    7. Driver Side Mirror Glass Replaced
    8. Hood Shock Replaced
    Things Still on my To-Do List-
    - Install MagnaFlow 36005 Universal Cat
    - PASS SMOG!!
    - Repair Odometer
    - Repair side mirror switch
    - diagnose/Repair ABS Light
    - Diagnose/Repair the horrible rear suspension Squeaking noise
    - ALOT more Im sure
  • IronicBenzTech
    • Nov 2011
    • 46
    So During My Oil Change, I found the PO (or whoever) stripped the drain pan hole. See The drip?
    [ATTACH]49444[/ATTACH]
    Since I didnt have means at the time to repair it, I continued with the oil change and snugged the drain bolt to a mere 6 Nm (lol)...
    [ATTACH]49442[/ATTACH]
    Drove it for 2 weeks, while i waited for a Time-Sert Kit (1215C for the Curious) and a Day off.
    Here it is drilled out and Counter-Sunk
    [ATTACH]49445[/ATTACH]
    Newly Tapped Threads for the Insert
    [ATTACH]49446[/ATTACH]
    AAAnd the New Insert installed w/ Red Loctite (its all i Had)...Torqued drain plug to 25 Nm no problem- AND NO LEAKS!!
    [ATTACH]49447[/ATTACH]
    In My opinion, This is the BEST way to repair stripped out threads.Easy As Hell, And its the way my shop foreman prefer over heli-coil or Next size up method
    • DREWHALL
      • Feb 2006
      • 1207
      Looks like a sturdy repair. Good start.
      • lambo
        Captain Scene Points
        • 10953
        Lucky, when I tried to tap mine, I did it crooked and fucked it up...
        • 325ix
          • Aug 2009
          • 7783
          Nice start! I would look into doing all of the rear-end bushings when you find the culprit. It is a pain to get it apart, so you might as well get it all done.
          I have that same HU and I love it!
          • IronicBenzTech
            • Nov 2011
            • 46
            the 1215c kit comes with an alignment sleeve thats sits on the oil pan hole flush so it wont go crooked
            • Julien
              • 7472
              I just used an oversized drain plug bolt. nice getting it done though :)
              Build Threads:
