My 91' 318is - now with S50 cam'ed M52 & lots of new parts
  • Jszy25
    • 352
    We'll I guess its time for a "build" thread, I guess you could call it. I picked up my 1991 318is with ~110k on the clock for a very reasonable $1,500. The car was daily drivable when I bought it. I drove it for about 1 year, completely stock other than the sound system the PO had installed.
    I ended up with an M52 + ZF trans from a car that I bought to part out. I originally had thoughts of doing a turbo setup on the M42, but once this engine and trans fell into my lap, I knew I was doing the swap.
    So out came the M42 & trans and was sold in a couple days.
    I figured at this point, it was a good time to spend some money, do it right, and refresh a lot of worn parts in the car. Here is a list of the maintenance items I did before the swap and parts needed for the swap:
    Front control arms
    FCA bushings
    Brake pads/rotors/sensors front & rear
    New parking shoes & hardware
    Bilsteins front & rear (cut 1 coil from the front stock springs and installed E90 drop hats)
    Sway bar end links front & rear
    Sway bar bushings front
    Installed steering rack from 98' 328i (PS delete plate installed)
    Tie rod assemblies
    Strut mounts
    Rear shock mounts
    Water pump
    Thermostat & housing
    M42 rad & new hoses
    Spal high perf. 13" fan
    Then it was time to address the M52. I was told by the PO that it had high mileage on it when I bought it, but it was in good shape.
    In went my S50 cams that I bought for a good deal. The S50 cams drop right into the M52 trays, fortunately. I also used a Beisan systems kit and rebuilt the VANOS unit. Also swapped in a metal oil filter housing for the plastic one.
    I then installed the E34 M50 oil pan and pickup, I also tacked the oil pump nut in place since I was right there:
    Then I took a wire brush, some chemicals and some elbow grease to clean up the block. Then I threw a coat of paint on it:
    Then it was decided that while the engine was out, I should remove some unwanted items from the bay and give it a coat of paint as well:
    Before I dropped the engine in, I did some more required work for the swap like run new fuels lines in the engine bay, modify and install an E21 brake booster, installed the throttle cable, etc.
    Getting prepped for the swap (the clutch that came with the donor car was in very good shape so it was re-used, I just cleaned up the flywheel with an abrasive disc). I ditched the AC bracket at this point as I don't plan to have AC in the car:
    In went the engine w/ new E34 mounts and then I bolted up the trans w/ new E30 mounts and a new guibo to mate up the DS. I also installed a new OEM Z3 shifter, bushings, clips, etc. Finding a few cut wires in my OBDI harness that was given to me was a bit nerve racking, but it all worked out:
    The car is now up and running and a blast to drive. The 4.10 open diff in the car has GOT to go soon though :). I am now looking for a 2.93 LSD to swap in.
    Maximum PSI, (where I used to work and currently still work remotely) built the exhaust for me. I cut and welded the stock OBDII front header to work around the subframe and they built the Y-pipe into a 2.5" single with a 2.5" universal cat and a single Magnaflow muffler. I am super happy with the sound and I don't stink like exhaust fumes after driving it.
    I did some aesthetic mods as well like a new IS lip and I painted the kidneys and grills black. I've got a bunch of other things I want to do.
    Here is a picture of the car as it currently sits:
    Here is a video clip of the exhaust (iphone 3gs video):
    I will be posting more pictures when I get a chance to take some decent ones. I still need to put the wire harness cover on, the engine covers, my Sparco strut bar, and possibly an OEM M20 airbox. Then I'll take some finished engine bay shots.
    Thanks for looking!
    91' 318is - OBDI M52/ZF swap w/ S50 cams
  • FunfGan
    • Jan 2011
    • 4958
    Awesome! Simply awesome.
    Go here be happy!
    Ratchet Garage e30 V8 build.
    • catuned
      • Jun 2011
      • 2324
      great
      Work We Do
      CAtuned Feedback Page|FB CAtuned Page
      http://www.catuned.com
      • CrusherCurtis
        • 2532
        How close is this setup to s52 power?
        • entrepreneuR
          • 206
          Nice pics
          • Jszy25
            • 352
            Thanks everyone
            Good question. At some point, I'll def get it on the dyno and will post the results.
            • A_Whelan
              • Jul 2010
              • 691
              I enjoy a good build thread with good pictures, well done.
              r3vlimited Lanyard Group Buy!!!
              • scabzzzz
                Estado de mierda de encargo
                • 6870
                fap fap fap fap
                • 325ix
                  • Aug 2009
                  • 7783
                  Looks nice but, why did you just cut the springs while they were out? Why not install something a little stiffer to go with your newly found power?
                  • Jszy25
                    • 352
                    I wasn't even planning on lowering it at this point, but the car always had a bit of reverse rake to it, which I hate, so I cut one coil out. Hardly noticeable at all, but to me, I like it with the E90 hats.
                    • 325ix
                      • Aug 2009
                      • 7783
                      Fair enough! I can't stand my suspension with all of it's lean. The car must be a blast to drive.
                      • Jszy25
                        • 352
                        Yea its a fun car. It was long overdue for new control arms, bushings, brakes, and shocks, so it feels like a new car again.
                        I want to get either a Momo or a Sparco steering wheel for it. The stocker has got to go. Euroweaves wouldn't be bad either ;) The whole car will get painted at some point down the road, but no time soon.
                        • robrez
                          • Jul 2008
                          • 3376
                          As an m42 owner and fan, I ain't mad at you. Good job.
                          January 2012 COTM
                          • Isostar13
                            • Nov 2011
                            • 288
                            Nice pics, thanks for sharing.
                            1988 325ix
                            • Jszy25
                              • 352
                              Haha thanks man, your car is super nice man.
