Boosted Vert Project
    Been working on my turbo project for multiple months now. Got it running for a few weeks before I decided to give her a little more boost.
    This was the result...
    So 17psi was the limit of the stock head gasket with my tuning setup at least. Next up was to pull the head and replace the gasket.
    Pulled head/intake manifold/exhaust manifold/wastegate/downpipe all as one, seemed much easier.
    Pistons looked great, gasket did not!
    All buttoned up!
    After I put her all back together I turned the boost back down to 8psi. Its still tons of fun especially in the rain. Still an ongoing project as this is a pretty cheap/homemade setup. Comments and criticism welcome as always.
    Specs:
    M20B25 (stock internals)
    Metric Blue headbolts
    Stock Goetze headgasket
    Modified early ebay manifold
    Tial knockoff wastegate (5psi spring)
    Knockoff boost controller
    Holset Hx35 (open downpipe)
    Ebay intercooler
    Custom charge pipes
    Motronic 1.3 with timing retard chip
    M30 AFM
    Begi 2025 RRFPR
    AEM wideband
    1987 325i-M60b44 swap
    Looks good. I love your color choice! Mine:
    1987 Delphin 325IS
    LS1•TSP 228r• condor speed shop solid subframe, diff, fcab, mounts•Airlift air ride suspension•e36 ps rack•Eibach sways•16" Spal puller•bbk 310mm front & rear•17" BBS RS•
    Build Thread
    1993 alpine 2 325IC
    •Ground control coilovers•16" BBS RS• momo woodgrain
      Holy shit!! 17psi? How long did run that much boost?
        this. Damn.
          You could run 17 psi no problem with megasquirt and proper tuning.
          1987 Delphin 325IS
          Build Thread
          1993 alpine 2 325IC
            No megasquirt and no proper tuning. I pulled 17psi for all of ten pulls, but it was worth it. loving the turbo now that its tuned @8psi.
              Hope mine is as clean as your one day, what paint did you use on the exhaust housing?
                Ceramic coated it, but I have seen people use VHT flameproof with success
                1987 Delphin 325IS
                Build Thread
                1993 alpine 2 325IC
                  so sick! got any vids?
                    inspiring me to go turbo... choices choices
                    Delphin '87 325i Vert
                      how much was your complete turbo set up?
                      http://www.steinbachphoto.ca
                        No videos yet, hoping to get a couple this weekend. All in all the whole setup ran me about $800 or so. This is with a ton of help from mattdk318i who is an awesome welder and had multiple parts he sold me. Go turbo! Just the sound is worth it!
                          800!? Wow, most of scored some nice parts. Soooo the gasket went cause you're not on a MS or a proper tune?
                          Got all da Alpine bitches mad cuz my main bitch Calypso.
                            Yep, got the turbo/piping/injectors/chip/wideband etc. for $500. A great deal from a friend. Gasket went from a few causes. Tuning on the motronic and some head studs would have helped. Megasquirt is only as good as the tune you can write
