agent's build thread: Klaus
  • kid325e
    • Sep 2007
    • 6422
    Are those "cowcatcher" valence mounting brackets?
    Sent from my LG-P999 using Tapatalk
    clutchCTRL!
    Move with a purpose.
    - 1991 325iX 4dr/5spd
    - 2000 323i AT
    2016 Mazda CX3 Sport AWD
    • agent
      Vice Grand Pubaa
      • 7960
      Yep, on a tip from Levent I got them from Chuck at SunSpot. He has them available on eBay but in very limited supply. I understand that once they're gone, they're gone.
      http://www.ebay.com/itm/310382740928
      http://www.ebay.com/itm/310382727451
      Originally posted by kronus
      • e30damen
        • May 2007
        • 945
        Nice job!
        I love to see builds like this!
        You're saving it
        PNW E30 Crew : 1991 E30 S50, 2000 E39 M5
        Follow my S50 build
        : MY S50 E30
        Follow me on instagram : @damendesign
        E30 T-Shirts | M3 T-Shirts /Prints
        • dball4
          • 560
          I lime your wheels.
          1989 M3
          2008 135i 6sp
          • TS87325IS
            • Sep 2006
            • 821
            Looking good! Can't wait to see it in person.
            mods: just meat and potatoes under the hood and wheaties on fire out back ;)
            • thowes24
              • Jul 2010
              • 121
              sub'd!
              • Den_k321
                • 1248
                looks awesome!!
                do you have more pictures how you installed sideskirts? thanks!
                1988 325is S50 in-progress.
                http://www.facebook.com/E30LocalCrew
                Few pictures:
                http://www.r3vlimited.com/board/showthread.php?t=255061
                • agent
                  Vice Grand Pubaa
                  • 7960
                  Those are most (if not all) of the pics I took, though I'll be happy to post a more detailed description of what we did as soon as I have time to sit down and type it out.
                  • Zacm829
                    • Jan 2008
                    • 1919
                    Great Progress! Love the RD wheels. Any engine plans? Your
                    going to have to keep up with some quick E30s at the rally...
                    1987 325i-M60b44 swap
                    • MattAvino
                      • Jan 2011
                      • 2147
                      87is. solid.
                      E30 buildy things
                      http://www.r3vlimited.com/board/showthread.php?t=195286
                      • agent
                        Vice Grand Pubaa
                        • 7960
                        I can't wait for you to see it either. It's been a long time coming!
                        Originally posted by MattAvino
                        87is. solid.
                        I'm sure my friend TS I quoted above you agrees - thanks!
                        Originally posted by Zacm829
                        Great Progress! Love the RD wheels. Any engine plans? Your going to have to keep up with some quick E30s at the rally...
                        For the time being I'm doing this one RobertK Style: all show, no go. ;)
                        • agent
                          Vice Grand Pubaa
                          • 7960
                          Originally posted by Den_k321
                          looks awesome!!
                          For installing the side skirts, we basically followed bernzpeed's install guide, though we ran a strip of wide masking tape down the rocker panel instead of using white out on the tips of the white pieces. You can see this tape in post #9. The first two pictures are the passenger side, the next two are the driver side (with the tape flipped as described below) and the last one is the passenger side test fit just before lining up the rear fender well holes and pop rivets.
                          We attached the white pieces to the skirts (the ones pictured from 0:30-0:40 in the new video), then held the skirt up to the car and applied pressure to it, pushing inward and upward at the same time in the general direction of the center console.
                          We repeated this process a couple more times, then drilled through the masking tape at what was more or less a triangulation of the indentations in the tape made by the white pieces. Once the passenger side was complete, we used the same piece of tape for the driver side, though we flipped it over and used it sticky side out by securing it with some smaller pieces of tape. That way we used the top of the tape for both sides so that the holes were drilled the same distance from the bottom lip. Hopefully that makes sense - it's difficult to articulate. Test fitting of both sides (without the green anchor grommets) lined up as closely to perfect as I could have hoped for without a template being supplied.
                          I agree with her recommendation of not using the clamping bolt, as the existing screw in the lower lip of the rocker panel looks like it's going to work just fine for attaching the small fender piece. Big thanks to her for the installation info.
                          • agent
                            Vice Grand Pubaa
                            • 7960
                            Some pictures from yesterday when I went by to drop off the mounting screws to hold the mirrors in place for painting...
                            • agent
                              Vice Grand Pubaa
                              • 7960
                              Speaking of side skirts, while I was typing the last couple of posts Arnie sent these...
                              • agent
                                Vice Grand Pubaa
                                • 7960
                                And these of the freshly painted valance...
