my project (plastic late model alpine white)
  • inwoo
    • Aug 2007
    • 74
    See below (its a copy of my story posted on the car lounge)
    Hope you enjoy! :)
    After a several years on the TCL, and many thousands of E30 posts, i could not resist passing up the perfect e30 to fix up. My search began about 6 months ago, actively looking for a late model e30, 325i or is, black interior, 5 speed, and NOT a convertible. (It rains so much here).<p>I am glad to say that no more shall i search for an e30, (for the immediate future), and hopefully over the next couple weeks i will be fixing this one up to a usable daily driver state.<p>Some Specs.<p>1990 BMW 325i, black leather, 5 speed.<br>120,xxx miles on the clock (still functions !)<br>Interior is in very good shape for a 17 year old car (sorry couldn't snap some pics)<br>Muffler and suspension is shot.<br>Idle problem, either the TPS or a vacuum leak (best guess)<br>timing belt / water pump done 5k ago.<br>rebuilt head.<br>Control arms done at 90k<br>steering / brake flush 2k ago.<p>What i plan to do:<br>Chip<br>Suspension + Springs (Any recommendations?) it will be a daily driver, and 5% of the time see some track use.<br>Replace Muffler<br>New plugs<br>Clean injectors<br>Short shifter, probably from a Z4 or an e36 m3<br>tranny flush / diff flush.
    well, alot of cosmetic things have happened over the years, and everything is getting buttoned up...
    Here's a pic for anyone motivated to jump into an e30
    work done! (below)
    Date Description
    8/13/2007 Purchased the Car
    8/18/2007 Replaced Muffler with OE Muffler
    Cleaned up intake area
    Replaced Intake gasket, and elbow gasket from ICV
    OE Air filter
    6 Spark plugs TQ 25Nm
    1QT pennzoil 10w-30 synth
    8/19/2007 Chevron fuel injector cleaner , + first day of 92 octane
    OE Audi power steering fluid top off
    Replaced windshield wipers with OE
    Washed, clayed, waxed
    checked oil level, (even with yesterday), added 1/2 quart to bring the dip stick level to a little over 1/2 way
    checked lower intake area, no oil drips yet.
    screw down the lower front panel of drivers area
    8/25/2007 penn plat - 10w30 4.5 quarts
    OE filter
    checked lower panel ground, (ok)
    10/6/2007 blistien sport shocks / struts all 4 corners
    new front rubber spring pads
    new rear rubber spring pads
    upper front shock mount
    H&R sport springs
    ST front and rear sway bars
    new front tie rods
    rear shock mounts (lifetime mounts)
    HID install
    euro smiley headlights
    euro grill + euro kidney grill
    10/12/2007 alignment
    repair of front sway bar mount (broken tab)
    10/18/2007 tranny fluid : redline mt-90 gl4
    diff fluid : redline 75-90 gl5
    checked that the fuel sender is bad. (it wasn't bad...)
    10/23/2007 konig remember 16x7
    kumho 225/45/16 ast 7
    bmw 70mm center caps
    replaced fuel sender
    10/25/2007 rolled rear fenders, haury's lake city
    7/27/2009 Removed head from engine
    7/5/2010 Put in head.
    rebuild head - dipped, skimmed, valve seals
    head gasket, new studs, nuts
    10/11/2010 New timing belt
    new accessory belt (minus ac condenser)
    dino oil / new filter
    new air fliter
    OEM coolant
    4/2/2011 IS sport seat upgrade (front 2) (leather cleaned)
    4/19/2011 parking plastic (smoked) 1 set
    ECU Chip bosch 173 (upgrade ebay chip)
    replace defrost button.
    fill more coolant and steering fluid
    replace fuel gauge from motometer gauges (fuel gauge still broken)
    4/20/2011 fixed turn light being too fast
    swapped heater core hoses (filled more coolant)
    removed fog lamps
    fix headlight alignment ...
    4/21/2011 put in bmw original floor mats.
    OEM BMW ///M Leather Shift Knob BMW Part# 25 11 1 221 284
    4/26/2011 used "stereoinstaller1" left fuel sender Fixed the gas gauge!!
    5/14/2011 surface rust repair
    kenwood kiv-bt900 (send back in for RMA due to right rear channel broken)
    JBL® KAPPA FIVE-Z Five-Channel Class-D System Amplifier
    monoprice rg-59 wiring RG-59
    Remote keyless entry
    leather shift boot
    replaced toolkit missing items - now complete
    5/20/2011 mounted rear component speakers
    cadence Zrs-55ks 5.25" 240 Watt (Pair) Super Slim 2 Way Component Speakers
    5/22/2011 wire 30pin to 30pin high / low beam relays with 18 gauge wire
    install 13obc / stalk / gong / control
    fixed light bar with radio shack 6v bulbs
    interior all buttoned up.
    fixed headlight wiring on the passenger side
    mounted speaker covers, and padded crossovers
    fixed plastic broken piece on the gong
    5/27/2011 fixed broken defrost button light
    fixed the passenger window switch
    fixed headlight wiring on drivers side
    re-installed kiv-bt900 that i got from RMA.
    wired the speakers up again
    replaced gong with a working one
    Fix the windshield wiper hose and mount to tank
    put in m50 injectors (pull fuse 11 and run engine) clean injectors
    leaking coolant near the intake manifold (clean wires)
    aligned the HID beams higher
    5/31/2011 installed shortshifter 328/m3
    installed shift boot
    pull out right front tweeter
    6/2/2011 wire extra speaker wire to right passenger, and wire up woofer
    pull seatbelt through correctly
    punch out ski-pass through
    6/4/2011 pull out trunk tar
    luke box 10" ported subwoofer box
    re-wire rear + and - mistake
    install obcon ob-104 dvc
    6/5/2011 re-install box to fit in trunk (sanded body filler)
    mounted recessed bolt fittings in the box.
    get sewing kit and repair the broken carpet tab, gorilla tape
    remove some foam from the back seat
    6/6/2011 shaved tweeters plastic housing to fit tweeter enclosure
    mounted 1/4" 20 3" bolts Phillips into mount box secure to back of the car
    removed extra speaker wire
    re-wired the speakers back into the amp
    6/7/2011 "mount and wire new tweeter to the passenger front speaker pods
    SEAS Prestige 27TFFNC/G (H1396) 1"" Textile Dome Tweeter"
    6/16/2011 mtech 2 steering wheel
    6/29/2011 reinstall kappa five z
    7/29/2011 black trim paint with sem 39143 (did front grill)
    Paint and install IS lip / + front valence re prep and spray
    replace fog light, h3 55w yellow fog light bulb
    8/2/2011 replaced all lip tabs (because the plugs were snapped off)
    amp returned
    fitted ps trim piece
    8/6/2011 welded reinforced trailing arm tabs from turner, sprayed rustoliem
    fixed sway upper mount and re-lubed
    removed washer from upper mount, to get nyloc washer to fit correctly
    added new distributer and ignition rotor
    8/15/2011 prep rear bumper for paint and new trim.
    8/16/2011 prep front bumper for paint and new trim
    8/30/2011 put on repainted bumper (front and rear)
    5 piece euro trim
    Okay way more work to list.. but here are some pictures!
    5 piece euro trim
    4/1/2012 pulled airbag plug
    replaced 5.25" speakers in the front (madisound - paper cone)
    plugged the antenna, and sealed
    headlight foam strips to seal
    filled some coolant
    4/7/2012 new clutch / brake rubber pad
    took out old steering rack
    cleaned a bit of oil from the bottom of the car
    4/14/2012 steering rack upgrade (need to punch firewall) 2.5 lock
    punched firewall
    sealed with grey primer
    DIY alignment, pulls slightly to the left
    CHS11 fluid
    windsheild washer sensor replacement
    new e36 tie rod ends
    new hoses from nebar hoses (High pressure, 2 low pressure lines)
    4/21/2012 wash, clay, polish, wax
    passenger front speaker panel replacement
    4/22/2012 JL W6v2-D4
  • K1CKBAC
    • 306
    Very Clean!
    My expectation is an immediate 5 speed swap. Autos suck more than a 50 year old whore.
    • evoDRichie
      • Jan 2010
      • 1743
      that steering wheel is fresh wish mine looked that good
      • 240zs30
        • 583
        Wow, so much detail. Nicely done.
        • !AjHoWzA!
          • Jan 2010
          • 1140
          Very nice! Like the wheels!
          '91 318is
          • Acehye559
            • 1033
            More pics more pics...
            • iChase
              • 158
              Bump for a Washington dood!
              Maybe Ill see you around somewhere in the streetzz
              My Sig killed itself. :wgaf:
              -88 325is Zinnoballer
              • mr.vang
                • 4371
                i love clean alpine
                • bmwstephen
                  • 2463
                  what usb cig lighter accessory is that? looks super low profile
                  • bmw325csi
                    • May 2007
                    • 4045
                    nice ride
                    harry/harout
                    • ScHpAnKy
                      • 1573
                      same steering wheel, radio, and shift knob as me!
                      good taste! haha
                      91 318i | 87 535iS
