My prefacelift (smaragdgrün) e30 m50b30 build
  • NufnSus
    • Apr 2012
    • 119
    #61
    Originally posted by Jib05
    hahaha ye olde "when you see it"...
    How did you mount the Style 5s? Adaptors?
    Nice project btw, keen to see where this goes, especially the M50B30 Stroker!
    • litu
      • 848
      #62
      OMG thats looks awesome.....
      https://www.facebook.com/Cry_77_IX-110483784967661
      https://www.instagram.com/cry_77_ix/
      • Jib05
        • Aug 2012
        • 149
        #63
        Yeh, she was bored while I was taking photos... too bad right after taking them, on the way to the grocery store I got rear ended.
        yeh I have adapters. Have to repair them though as the previous owner stripped a few threads. Either going to heli-coil them, or drill and press new studs in.
        Thanks I want to see how it goes too! Also with an extra light m20 flywheel should r3v pretty sweet!
        Anyway, what does r3v think? should i black out my busted chrome bumper and let it be, or get a replacement?
        .................................................. ...................sigpic
        .................................................. ............................. ......M50B25 3.1L stroker
        • Blackout
          • Apr 2011
          • 4130
          #64
          Originally posted by Nairb
          Cut the springs, take a brillo to the hood and rust it out, crazy camber on the wheelz and a budget turbo system and you'll have yourself a rockin' ride!
          » PARTS FOR SALE
          » TRANSACTION FEEDBACK
          • Jib05
            • Aug 2012
            • 149
            #65
            Small update!
            Its been slow since i moved house on the weekend. But on the plus side I now have a double garage!! ;D
            We tore down my m50b25NV motor and had a look at everything.
            All the cylinders looked identical! Taper and oval checks made sure of this!!
            then we went on to test fit the piston(s), crank and rods
            after all of that we cleaned and masked the block and painted it
            All just in time for new parts!!
            Thats all for now!!
            • Jib05
              • Aug 2012
              • 149
              #66
              Another small update, have been working on a harness adapter. i think i have it all done correctly!
              also have been sorting out where the magic will happen
              I saw a picture of an acoustic cover that was wrinkle black so i got started
              dirty
              clean
              first coat
              Have no F*kn clue where this water drop came from?
              On a day like this
              also got started on my obd2 exhaust manifolds
              comparison
              I got round to cleaning up my sump and timing cover
              Until next time!
              • golde30
                • 11464
                #67
                Why did you chop the manifolds?
                IG: @Baye30
                • efficient
                  • Feb 2012
                  • 3312
                  #68
                  Dope color!
                  • Jib05
                    • Aug 2012
                    • 149
                    #69
                    Because in NZ we drive on the other side of the road, and cars are RHD, so need to take off an around 20mm to clear the steering UJ
                    Originally posted by efficient
                    Dope color!
                    thanks! Entertaining the idea of this color in a satin finish.
                    • golde30
                      • 11464
                      #70
                      IC, makes sense. I can't see anyones location on this tapatalk forum app.
                      IG: @Baye30
                      • Jib05
                        • Aug 2012
                        • 149
                        #71
                        Another update,
                        got started on taking the m20 out, went pretty smoothly. Its all ready to come out just waiting on the engine crane. pics!
                        The coolant looked pretty sweet!
                        Didn't take very long to get everything up top out and done
                        This broom is awesome if you have a painted garage floor!
                        And here's a little DIY on how to make a snack while you procrastinate from doing work.
                        Le avocado
                        Le cut
                        Le half avocado
                        Le hack seed
                        Le twist
                        Le seedless avocado
                        Le toast
                        Le spread
                        Le salt
                        Le pinch
                        Le grind
                        Le pepper
                        Le pinch
                        RESULT!
                        Leave dishes and what not for partner/mother to find. :D
                        ok some Qs
                        is this the brown top temp sensor that i need?
                        Thanks for looking!!
                        • totheredline
                          • Jun 2013
                          • 762
                          #72
                          Diggin the NV stroker! What are you doing for camshafts?
                          = Heidi 1988 325 -> 335i. 7200rpm built M30
                          • Jib05
                            • Aug 2012
                            • 149
                            #73
                            Thanks! There's is a company in NZ called Kelford cams. I have been in touch with them. They can make cams to schrick specs. So I am thinking about the ol' intake cam on exhaust side with a schrick intake cam.
                            • Jib05
                              • Aug 2012
                              • 149
                              #74
                              update!
                              Pulled the motor tonight! It went really well. I got this old engine crane from a friend of my dad 2 years ago, and was sitting in my dads yard since!
                              (Cool thing about it is that it has a built in load leveler)
                              PS big thanks to my mate Marcus for picking up my crane and helping me pull the motor! Def great to have another pair of hands!
                              coming up!
                              upper!
                              even more upper!!
                              gnarly angle to practice putting the m50 in! :jk:
                              out
                              Pic for the lolz
                              packed away until tomorrow
                              where the new magic go vroom thing will go
                              that's all for now!
                              • jharrel
                                • Aug 2012
                                • 130
                                #75
                                nice looking work! what do you plan on doing for tuning with the non vanos setup?
