:up:
Another Alpine Sedan
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. -
so i finally started taking out the engine out of the sedan today
glad i finally had the time to remove the engine
then i gathered up some tools to remove the valves off the m62TU to put onto my m60b40 heads (same valves just different springs in them b40 is dual m62TU is single)
these were my tools of choice Pen/pencil, valve compressor/ copper tube i got at home depot that i just cut a hole on the side with a dremel
started by removing the cams/lifters then placed the copper tube on the springs to get the clearances i need to use the valve compressor
then i used a pencil/pen to "poke" out the valve locks
and viola your valves can now be removed and before you know your head is bare,
thats it for today since the rain was making it really hard for everything since i removed the engine out in the rain, later on this week i should be able to clean up the valves and start lapping themComment
