Wash, Ironx, Wax after taking it out of storage for the summer
  • noid
    • 1537
    Thought I would intro my car, its my second E30 that I have owned since last June, but has been in storage since September. While in storage I changed:
    Falken 912 tires x 4
    Treehouse racing control arm bushings
    New control arms x2 (lemforder)
    New tie-rods
    Rebuilt injectors (flow matched/bench tested)
    Valve adjustment
    Timing belt/waterpump/tensioner
    Alternator/power steering/AC belts
    Black leather interior
    Re-installed stock radio
    Removed aftermarket alarm
    Antenna gourmet
    Euro smileys
    Bilstein HD shocks (car has factory m-tech springs that I retained)
    173 ECU
    New odo gears
    Derlin shifter carrier bushings
    AKG DSSR
    Both Transmission seals
    Engine mounts
    Transmission mounts
    Strut mounts front and back
    Glove box handle/lock
    Exhaust hangers middle and back
    Catback gasket x2 + header to midpipe gasket
    CV boots inner and outer
    OEM Subframe bushings
    OEM Trailing arm bushings
    Shifter joint
    OEM Differential mount
    OEM Diff Gasket
    Sway bar links front and back
    Oil filter housing plug (revised design from the dealer)
    T-fitting for the spray nozzles
    New wipers
    Shifter boots (the actual boot and the rubber boot below it)
    Thermostat
    Radiator
    Window regulator
    Door seal
    Trail light seal
    Guibo
    CSB
    New fluids front to back (diff, transmission, engine, coolant, etc).
    Time-sert kit for the oil drain plug
    Turn signal stalk
    Rear sway bar links
    Spark plugs (NGK)
    Reverse light switch
    Fuel pump
    Fuel filter
    Distributor cap
    Distributor rotor
    Ignition wires
    Valve cover vent hose
    Coolant hose (from thermostat housing to throttle body)
    Tool kit for the trunk
    AFM
    O2 sensor
    Gas funnel rubber surround
    New group 49 battery (and proper venting)
    All new bulbs all around
    Coolant to heatercore outlet hose
    I am sure I am forgetting some stuff, the above is all I can recall off the top of my head.
    Finally had a chance to wash the E30 after taking it out of storage for the summer.
    Also the first time I had a chance to try Iron-x. Had some rail dust from a California to Ontario trip and it did an amazing job of cleaning it up. It worked so well I decided to skip claying the car because the clay kept on coming up clean.
    Waxed the car after with turtle wax.
    Car is 87 325is, an all numbers matching except manual transmission was changed for another manual transmission at some point, accident free, original paint, life long California (until my acquisition) car.
    Fresh after the wash (everything open to get optimal drying):
    Iron-x doing its job, unfortunately I don't have many pictures from when I did the process:
    Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
    Your resource to tools and tips: www.rtstools.com
  • Vtec?lol
    • Dec 2009
    • 3278
    Your front caster is omgsh....
    Any reason you went that route instead of m3 offset CABs?
    • ZoomZoomBoom
      • Oct 2012
      • 475
      IronX works well but the smell is horrid, haha. Why did you use Turtle Wax as a LSP after spending the time to decontaminate the paint? It's pretty much at the bottom of the barrel and isn't hard to find a better LSP for looks and durability even at the local auto parts store.
      1989 325iC Zinnoberrot
      • noid
        • 1537
        Solid > m3 cabs. With all fresh bushings and shocks the treehouse cabs actually don't feel harsh at all. My GF road in the car and asked me why it felt smoother :rofl:.
        The smell is supposed to be Cherry and it does KIND OF smell like cherry but I would say it smells closer to skunk. I didnt mind it all that much.
        I already had a bottle of turtle wax that my GF gifted me a year prior. It was their "Super Hard Shell liquid wax" stuff.
        • NickL
          • 562
          Is that an imola yellow golf?
          1987 325is - S52
          • noid
            • 1537
            Yes?
