318i Sedan Intro/BuildThread :smiles:
  • nqphoto
    • Aug 2012
    • 21
    Hi. Well before I get to the good stuff I guess I'll introduce myself. My name is Nelson, I'm from Miami, FL and I'm an automotive and motor sports photographer. I've had quite a few cars in the past, mostly japanse...mostly Nissans, but never anything european. I've lurked/researched/read this forum for most of the past year and feel like I'm fairly ready to get acquainted with the community. My friend Guillermo (e30gangsta) put me on to this forum, and every since I've visited daily :D
    Ok enough babble, on to the car. It's a 91 318i Sedan, originally I got this car in a trade. I traded a Laguna Green 325i vert that I didn't own for long, mainly because the vert was automatic and had a lot of rust, plus I've always liked sedans and when I came across this offer, I happily took it.
    Quick pic of the vert...looks clean....but booooyy was it rusty.
    Ok, so then I traded that for the sedan I'm driving around now. That was about 8 months ago, for a while I wasn't too interested in modifying the car, at one point I almost sold it :(, good thing I didn't because I've become obsessed with E30s. So fast forward to this past weekend I decided to slowly start making progress with the car.
    First problem that needed to be addressed:
    Previous owner cut the springs on OEM shocks, so the shocks were blown and the car was slammed, causing me to bust three oil pans in a span of two months.
    So then I decided, fuck that I'm parking the car until I install proper suspension. Ideally I wanted a set of BCs, but the car has a couple more issues to address before I spend a grand on suspension, so I decided to take a more cost-efficient approach to address the problem and be able to actually drive the car. After reading the entire Suspesion Techniques springs thread, I decided to order a set along with GR2 front inserts and rear Camaros along with a set of E90 tophats, new bumpstops and bellows. Big thanks to Steve from Blunttech for the parts.
    And the work commenced! Comparrison between rear cut springs and ST units.
    Followed Grippy's advice from his blog and went to Home Depot to purchase the 3/8 threaded inserts for the rear camaros, they fit tight and secure, and since they're threaded, there's no fear of the inserts falling out.
    And the rear is done! Took a whole 15 minutes:yawn:
    Unfortunately Miami weather really sucks in the summer, it's either stupid hot or raining. I don't mind the heat....but the rain stopped me from doing anything else to the car for the day.
    Another aspect of the car that needed to be addressed was the interior. Now, I'm a really big fan of all black interiors, but it's really hard to find a complete set down here in the junkyards and getting it on the private sector is getting pricey. So I did the next best thing and decided to paint my interior parts. Starting with the seats.
    First I cleaned them very thoroughly with degreaser and dried them. Also let them air dry for a full day.
    Clean and ready for paint.
    Finished product. Paint sticks pretty damn good, I've been driving the car for a full week now and there's no sign of chipping or paint rubbing off. Have to let a least a full day for the paint to fully dry and stick. Pretty happy with the results.
    Gave the same treatment to the carpet, it was already "painted" black by the previous owner, but they didn't do a very good job since the paint didn't stick and was rubbing off.
    After, still gotta get a new glove box and dash. Little by little.
    So then Sunday, decided to start working on the front struts. Took out the housings and cleaned them up really good. Had to anyways since all the oil inside the housings had to come out.
    While the housings dried I decided to paint the wheels silver again since I didn't like the black before.
    Then I put the front suspension together, ready to go back on the car.
    Done for the day, springs are still settling. So I guess it'll go down a bit more, but I really don't car and wish it didn't since I'm really happy with the height as it sits. Car is dirty in this picture, I had literally just finished installing everything back on it. Still deciding what to do about paint, whether I should plasti-dip it red or wait longer for a legit paint job.
    It's a work in progress, and still needs a lot of work to be decent but at least it's moving in the right direction. Just got these smoked depo smileys from DTMFiberwerkz yesterday, still have to order HIDs and new fog lights in order to wire these up.
    Before that, I gotta change out the dreaded rear wheel bearings along with the brakes and motor/tranny mounts. I'll post updates soon. Thanks for looking :)
  • E30Runt
    • Jul 2013
    • 46
    Thanks for sharing the build so far. I'm in the same lines and just picked up an '84 318i coupe (hence "Runt") and slowly restoring.
    Can I ask what spray you used on the wheels and how did it come out? I was just thinking about plastidipping it.
    Cheers,
    Khoi
    1984 AW 318i - aka Runt
    • pilotskillse30
      • Dec 2006
      • 1957
      welcome...good progress,.to bad about the laguna vert
      • alB5
        • 785
        amazing shots!
        1991 318is -> 2004 R32 -> 2002 Jetta TDI -> 2014 FiST
        No E30 Club
        • nqphoto
          • Aug 2012
          • 21
          Cheers,
          Khoi
          Slowly but surely, we'll get there. I used Duplicolor High-Perf wheel paint. It was about 8 bucks a can at the local Advance Auto Parts. Just make sure you clean the wheels really good, sand them and prep them if you have the time.
          Thanks. I was a bit sad to see the car go too, the rust was so bad I didn't even want to document it.:(
          Originally posted by alB5
          amazing shots!
          Thank you.:-D
          • TimKninja
            • 2131
            You could probably buff all of that paint back .dont plastidip it!
            How do you like the feel of the GR2 fronts ?
            1985 325e M50TU(Sold)
            1991 318is Slicktop (Sold)
            1990 325is Brilliantrot S50/5 Lug Swapped.
            1992 525i Manual shitbox Winter Beater
            • Link
              • May 2012
              • 834
              Looks good, before doing anything to the exterior paint take the time and give it a really good wash, then clay bar, then buff the whole car, polish and wax it. You will be amazed at how much life you can get from an e30. I used harbor freights cheap $50 buffer and mothers products.
              View my build thread. http://www.r3vlimited.com/board/showthread.php?t=287724
              • nqphoto
                • Aug 2012
                • 21
                I'll look into it, paint looks good pretty good in pictures for some reason, but it's pretty bad in person. I'll polish a section on the roof and see how it comes out.
                GR-2s on the front feel pretty good. I'm coming from a horrible ride on the stock Sachs units which were blown. Overall they're very comfortable, if that's what you're looking for than the GR2s will be fine. They're basically a very slight increase in performance over stock, so you'll still have some body roll to deal with.
                • agent
                  Vice Grand Pubaa
                  • 7960
                  OP would be much easier to read (read: not require horizontal scrolling) if the entire thing wasn't set to centered.
                  Originally posted by kronus
                  • TimKninja
                    • 2131
                    Thanks for the feedback! Looking for something more comfy then my
                    bilsteins .
                    Some heavy oxidation remover will do you wonders . Brilliant rot does that over time. You will be really surprised. It'll look new after about 39 hours of work .
                    • nqphoto
                      • Aug 2012
                      • 21
                      bilsteins .
                      No prob, yeah I'm definitely going to try it out this weekend.
                      Fixed, sorry about that. Posted this on my work computer with a big 23inch monitor.
                      • nqphoto
                        • Aug 2012
                        • 21
                        Man, first off, I need to thank the R3V community for all the information. All the information shared on here saved me so many headaches and complications.
                        So, last weekend I had a chance to install my smoked depo smileys along with wiring up the HIDs and fogs. I really wanted to run the city lights as DTRLs so I had to tap into an ignition circuit, so they would be on all the time.
                        Through reading and searching I found you can tap into the heated seats circuit, if you have it. My car didn't come with heated seats but all the wires are there, so I was able to get those running.
                        Next up was wiring up the independent fog lights. I did the relay modification on a thread I found here on R3V, my OEM fogs were really bad.
                        And after putting a few WTB threads and searching on eBay and online for OEM units, I couldn't find any decently priced. So I had to go the cheap China DEPO route.
                        Of course the quality on these is horrible but they get the job done for now. I'm still hunting for a left side fog, since the right one can be still be saved. Left fog light's glass is cracked.
                        Next up is wheels and tires and the car should start looking a bit better. All I'll have left to address is the front and rear bumpers since they're cracked and the paint situation.
                        • SoCalKidz
                          • Jun 2011
                          • 244
                          What did you use to dye the carpet? I was thinking of doing it to my E30 as well.
                          • I8UR911
                            • Jan 2013
                            • 260
                            Nice start. The lights look good. Seats don't look bad but I'd be concerned with longevity. Great job though.
                            Sent from my XT907 using Tapatalk 2
