Gertech's '86 325es LSx T56 Swap
  • 5ickride
    • 2922
    #61
    Great job. That looks really cool. Must be fun to drive!
    • Gertech
      • Jul 2013
      • 180
      #62
      Thanks! Yes it's a blast! Can't wait for nice weather to put some miles on it. Weather in the northeast isn't ideal right now!
      • bmk
        • Feb 2011
        • 598
        #63
        What mode e36 radiator did you use?
        Worlds 1st LS powered e30 cabby.
        Cab
        billac: 92 LagunengrĂ¼n cabriolet + cadillac LQ9 + Nitrous + rotiform SJC
        Raphael: 88 LagunengrĂ¼n IX + Hella 500's + Red ACS type 1's
        Shaggin Wagon
        : 01 325xiT 5 speed
        91 MR2 GT3076TS + E85 = 505whp + antilag = wheelies
        88 CRX OEM+ 42mpg DD.
        • E30NJ
          • Aug 2013
          • 921
          #64
          Nice!
          • Gertech
            • Jul 2013
            • 180
            #65
            It's a stock M3 radiator, but I don't think those differ from the standard e36. I haven't had a chance to drive the car in warm weather since I just got it on the road in November, so I'm still not sure how well it will cool. Time will tell.
            • bmk
              • Feb 2011
              • 598
              #66
              What parts did you use to make the steering shaft?
              Also I'm assuming your using an e36 rack?
              Cab
              Shaggin Wagon
              : 01 325xiT 5 speed
              • jalopi
                • 2370
                #67
                He bought his steering shaft - the vorshlag shafts are nice, but very expensive. Search up e46 steering shaft e30, there's a guide somewhere on doing it.
                On a side note, I wouldn't do it the way that guide says to 100% of the way though... instead of cutting the shafts it's much cleaner to heat the shafts up and get the glue to "snake" out. Hard way = propane torch, easy way = outdoor grill/stove on a low flame
                ALSO
                Thanks for the shot of the rad clearance - I was under the impression that the LS water pump was a bit shorter, but if your clearance is about an inch it's probably the same as the ford - the z3 rad I've got is roughly 1" thicker than the e36 rads.
                • Gertech
                  • Jul 2013
                  • 180
                  #68
                  Yeah, I'm running an e36 rack. Made my own spacers to fit the rack in the frame. I bought the steering shaft from Vorshlag, made to fit the e30 with e36 rack. In hindsight I could have made the shaft by purchasing the parts separately from flaming river, but either way it's a quality unit.
                  • Gertech
                    • Jul 2013
                    • 180
                    #69
                    ALSO
                    Wow, if it's that much thicker I might have the same clearance issues as you! I'm hoping that the stock e36 rad will do it, but we'll find out when warmer weather arrives.
                    • jalopi
                      • 2370
                      #70
                      You'll probably be fine as long as your fan is good - if not, maybe upgrade to a mishimoto radiator? I don't know how much power you're putting down but I'm sure you'll be OK... imo the z3 mishi rad is way too big for our applications.
                      • Gertech
                        • Jul 2013
                        • 180
                        #71
                        Yeah I was looking at the e36 Mishimoto options. Might be the way to go if the stocker won't cut it. They also have some nice looking fans. I'll tell you one thing...I'm so damn sick of this snow shit! I just wanna drive my e30!
                        • efficient
                          • Feb 2012
                          • 3312
                          #72
                          Damn!
                          • Shangsta
                            • 1485
                            #73
                            Well done sir, well done.
                            :shock:
                            • Gertech
                              • Jul 2013
                              • 180
                              #74
                              Thank you! Much appreciated.
                              • evil-diesel
                                • Jul 2011
                                • 199
                                #75
                                wow... based on looks this is the perfect non-M e30!
                                i can only imagine how fun it is to drive...:pimp:
                                -chris
                                Early 323i
                                http://www.r3vlimited.com/board/showthread.php?t=214425
                                320i V8 Swap
                                http://www.r3vlimited.com/board/showthread.php?t=345807
                                M3
                                http://www.r3vlimited.com/board/showthread.php?t=310470
