SLC: 1989 Zinno coupe. Superlight, Super Functional *6spd swap inside*
  • mitchlikesbikes
    • Dec 2013
    • 858
    #256
    Originally posted by ahrensNW
    How are your wheels working out for you now? I'm eying the same set.
    Edit: because I'm poor :(
    They've been great so far. They clear the rx7 brakes too so I can keep running them with the new brake setup
    IG: @mitchlikesbikes
    • ahrensNW
      • Mar 2015
      • 1716
      #257
      Well, I just bought them. Out of curiosity, how much did you pay for your set?
      Hank Ahrens
      1984 Alpine Coupe
      1978 911sc
      • mitchlikesbikes
        • Dec 2013
        • 858
        #258
        I think they were somewhere between 450 and 500 shipped. I got the hub rings on eBay for $5
        • ahrensNW
          • Mar 2015
          • 1716
          #259
          I got a great price then. Sorry for derailing your thread for a bit. I think we'll have very similar cars soon.
          Hank Ahrens
          1984 Alpine Coupe
          1978 911sc
          • mitchlikesbikes
            • Dec 2013
            • 858
            #260
            more progress recently. i finished my brake pedal modification and got that back in the car. i also bought myself a new vise to use with my flaring tool and did the final trimming/flaring of my hardlines today. they came out pretty nice but the bends aren't pristine so i may redo them down the road with a better tubing bender. i cleaned up my MC and reservoir and used a bleeder screw i had kicking around to plug the 4th port on the MC that i don't need for my setup. crossing my fingers that nothing leaks when i bleed the brakes. i have a pile of parts ready to be bolted back on too but i decided to order some cheap KYB front shocks to get me by for a season or so until i can buy coilovers. wanted coilovers this year but with the house hunting happening i couldn't justify blowing another 1000 on the car after all the money i already spent on it this year. anyway on with the pics
            • mitchlikesbikes
              • Dec 2013
              • 858
              #261
              started diagnosing some cluster issues that have been plaguing the car and making me pull my hair out repeatedly for as long as i've owned it.
              no speedo/odo
              fuel gauge is wonky and inaccurate
              no cluster lighting
              i reflowed the joints today and ordered new SI batteries so hopefully that works for the speedo. i have power to my cluster illumination lights but the ground isn't actually grounded. going to have to do some wire tracing and figure out where the problem is there. i have replaced the left side fuel sender so i may replace the right side one too if the fuel gauge isn't working after the SI battery replacement. if i can't fix everything pretty soon i will most likely send the motherfucker to greg at bavarian restoration and have him refurb it. then i will know that if something isn't working that it's on the car side and i can troubleshoot a little easier.
              so sick of the cluster issues on the car. they're gonna make me blow my brains out.
              • mitchlikesbikes
                • Dec 2013
                • 858
                #262
                pulled the old strut cartridges yesterday. they were very old and completely blown bilsteins of some sort. they read "western germany" so they have to be close to as old as the car. definitely ready to be replaced.
                today i pulled the wheel bearings off of the spindles and got my knuckles/struts all cleaned up, then added a quick coat of black rattlecan to help keep them looking decent. my new cartridges came today so if the paint is dry i'll install those tomorrow. waiting on new upper strut mounts since mine were toast. i went cheap on those too because i'm only gonna run them for a year or so just like the shock cartridges.
                trying to upload pics but photobucket is blowing it. will get them up later
                • mitchlikesbikes
                  • Dec 2013
                  • 858
                  #263
                  progress finally (plus another minor setback). i installed my revamped struts and new LCAs tonight, as well as started assembling the brakes. everything went smoothly until i underestimated how weak the threads were on one of my reman calipers and stripped the hardline input. i ordered another reman caliper tonight so i will send this stripped bastard back to them as a core. also finally posting pics from the last update:
                  • mitchlikesbikes
                    • Dec 2013
                    • 858
                    #264
                    well, the weather is getting better here so i put the car back on the ground with my avids and re11s. also installed some condor door handles i got a while ago. i eyeballed the front toe to get it close enough to drive somewhere to get it aligned soon. still have some stuff to button up but my cluster lights are finally working, and i think i narrowed down my speedo issues to the sensor in the diff so i'm going to get one of those. today i ordered a small 2.5" resonator to put in the exhaust to help with the raspiness at higher rpms that's been bugging me. once i button that stuff up it will be ready to drive as long as my brake setup works right.
                    • mitchlikesbikes
                      • Dec 2013
                      • 858
                      #265
                      car is at firestone getting the front end aligned right now. i drove it about 40 miles to bed the brakes in and settle the suspension, then retightened everything before dropping it off. current to do list:
                      add resonator to exhaust
                      figure out why coolant temp gauge is working but won't climb past the blue
                      acquire a turn signal switch at the junkyard to see if that is what's causing some random turn signal/high beam issues
                      continue beating on the front brakes to ensure that they perform 100%
                      • jeenyus
                        • Aug 2011
                        • 2064
                        #266
                        Awesome. Look forward to seeing you around.
                        • mitchlikesbikes
                          • Dec 2013
                          • 858
                          #267
                          lots of interesting developments with the car lately. i had the two studs that hold the MC to the massive booster delete block snap on me. luckily i was in my driveway when it happened and not travelling down the road or things could have gotten ugly. i got some nice 10.9 grade studs to replace whatever came with the kit and things have held up okay since.
                          on my way to the local ikea for a euro meet last night i got hit by a 16 year old that ran a red light in his jeep wrangler. luckily he stood on the brakes and i ended up with some cosmetic damage and a couple gouges in the tire from driving the car out of the intersection where it was it. today i pounded the fender back out with a hammer to make it driveable again. not sure what i am going to do from here at the moment, most likely get a body shop quote and see what the figures look like. here are some pics of my finished door handles, a random shot from a meet, and the accident damage:
                          • Pantless Spency
                            It's McRib time!!!
                            • Feb 2011
                            • 7284
                            #268
                            that sucks man.
                            I rear ended someone in my e30 last year, similar cosmetic only damage basically im out a fender, hood, and some smilies and grilles (no big deal)
                            insurance paid me out 1200 after my deductible, im still searching for a zinno hood and fender tho :O but the car is literally perfectly fine, just a little uglier.
                            I would take the check :D probably a lot more e30 parts in SLC anyway, vegas is dried uo right now :(
                            • Euro4uwsm
                              • Mar 2016
                              • 26
                              #269
                              Great work i like rewards
                              hosting imagenes
                              • mitchlikesbikes
                                • Dec 2013
                                • 858
                                #270
                                Originally posted by Pantless Spency
                                that sucks man.
                                thats the plan, i'll probably fix it sometime down the road when i'm ready to paint it.
                                thanks!
