I guess its my turn.
  • matt325is
    • 409
    Well, just got the car up and running/CLEAN since its been sitting in the garage for the last 3 weeks, making the damn engine run. Anyway, Megasquirt now works, but needs to be tuned, I have all the intercooler tubing done/not ghetto-rigged.
    Here is a list of mods.
    2.8l Turbo Engine:
    TD crankshaft
    Bored to 85mm
    Ross Racing 85mm low compression (8.5:1) pistons
    High strenght wrist pins
    All new bearings/bushings
    All new gaskets
    32lb/hr Accel injectors
    IE adjustable fuel pressure regulator
    Garrett T04B turbo (turbine a/r=.60, compressor a/r=.50)
    Turbonetics 35mm deltagate wastegate
    Blitz dual drive blow-off valve
    Modified Starion intercooler with 2.5" tubes (core dimensions are 16.5x8x2.75)
    Custom 2.5" intercooler tubing
    Proturbo exhaust manifold adapter with custom wastegate adapter
    2.5" exhaust with Magnaflow muffler
    MSD 6-BTM ignition system
    Megasquirt standalone fuel computer
    A/F ratio, oil pressure, fuel pressure, and boost gauges.
    Custom manual boost controller
    Current compression is about 8.0-8.2:1 with thicker head gasket
    Exterior:
    Kopi Alpina wheels (17x7.5)
    H&R Cup Kit suspension (with thicker rear spring pads)
    Dual front lips
    Cut front valence for intercooler flow
    Future:
    Replica Mtech 2 rear spoiler (have in garage)
    Infinity front spoiler + custom splitter (maybe CF, with verticle supports)
    Ground Control Coilovers with high springrates
    Sideskirts (Breyton or BMP)
    Rear skirt (Breyton or BMP)
    Head studs
    Racing seats/harnesses
    Rollbar (possibly)
    I think thats about it, if I think of anything else, i'll post. This engine has been 1 year exactly in the works, and now getting finished.. I will have it dynotuned in the next week, and will post results.
    So pics, here we go.
    Peace,
    matt
  • Bill 84 318i
    • 1600
    Whoa, that ain't no Sparco bar - is it an IE bar? It looks like it has a better chance of fitting my car...
    Oh yeah, :up:. Although I'd have to say leave your body stock - it's the best look for a late model IMO.
    • e9nine
      • 1890
      ..Nice to see all your hardwork has paid off.
      A few ques:
      How come you didn't do the headstud conversion when you had the head off?
      What's the other thingymajig next to your MSDS ignition component?
      Is your TB modified? It looks a lil different at the part where the cooling lines "would" be..
      What's your Goal..street monster, track car or 0-60 car? Stiff springs will hurt your 0-60 as they supress traction ;)
      Nice job though :up: ...try add MHW smoked lights in the rear and you're a-ok 100%
      Waiting for new dyno sheet...
      • lowslowe30
        • 204
        If i saw that intercooler in my rear veiw mirror I would cream my pants as you drove by. I dont think the body needs and modification of any sorts either, it looks great as it is. Also what kind of muffler is on there, those pipes are frigging huge.
        • LarsG
          • 59
          It's beautiful, simply beautiful...
          The ONLY thing I don't like about it is the exhaust tips, a little too large for my taste, but it still fits the car.
          Very nice work!!!
          8)
          • Kavkazia
            • 394
            Matt, I love your car man, it looks gorgous, and that FMIC is looking sick, I cant wait to finish mine already!
            Later man,
            Amirani
            95' M3.
            90' 325i Turboed.
            87' 325eS Fixed.
            • Werksmini
              • 1658
              Soo soo jelous.
              I bombed Korea every night.
              • matt325is
                • 409
                Thanks guys
                Bill - Its a painted IE strut bar.
                e9nine - I didnt know where to get head studs back then, I should have however. The thing next to the MSD is the relay board for the megasquirt fuel management, it has 4 fuses, and 3 relays, it is where all of hte sensor wires plug into as well, from there, there is a 37pin connector/coord that goes into the car into the megasquirt computer. I dont have the coolant lines running through the TB anymore, I need the LEAST heat going through the TB, and I will suffer a bad cold idle.
                Where the ICV used to be is a Intake Air Temp Sensor, and on top of the intake manifold next to the throttlebody is a new WOT switch (actually 2 limit switches), because Megasquirt needed a real variable resistance throttle position sensor. I need the WOT switch for the ignition system to advance the timing.
                Not sure exactly I want this car to be, probably street/track car, i dotn really care about straightline acceleration (0-60).
                I bought the exhaust from my friend for cheap, so it works for now, it is very loud, so I might change it out later.
                Amir - I cant wiat until your car is done either! HURRY! :D
                Thansk for the compliments.
                matt
                • SlammedE30
                  • 741
                  Matt, it's disgusting. Give it to me. :D Just playin man, I truely can't wait to se it run on the dyno, I have a feeling it will be a very short run 8)
                  -Ted
                  • lodac
                    • 84
                    That just makes me want to start on my car badly.. I am so jealous.
                    • EVOIIIM3
                      • 315
                      Matt it's about time! :o
                      I would not plan on adding anything until it's all running properly! Who knows what the dyno will find!
                      Did you upgrade the clutch? I bet it will not last long after you get it tuned!
                      • mellowyellow88
                        • 71
                        That's a very, very nice looking car. Good work!
                        • rward325
                          • 251
                          Good work on the car Matt. A lot of hard work has finally paid off. Getthat thing tuned and lets see the results. Great looking car!
                          Just livin in the OC minus my E30
                          • OOMPH!
                            • 3487
                            looking awesome...I have no constructive criticism.....the car looks perfect :up:
                            • Wes325
                              • 563
                              How much horsepower are you estimating after everything is fully tuned. Your engine bay is awesome. I dig the 328i badging!
                              ________
                              CB1000
                              - 318is 4 life
