Hello, i am new to E30s and your forum. trying to figure how everything works in this forum. so far i have had her for 7months and im loving her. she was really dirty when i got her and in need of some loving. she was running and in stock condition. all she needed was a good bath and maintenance. here are some pics of how she looks today after she was cleaned up and service.
here's a list of things done as of 8/13/14
new hood shock absorber
fix power antena and new gromet
cleaned and regrease side view power mirror switch
new idle control valve hose and intake boot
ellipsoids lights
spark plugs (PO had different gap size all accross on old not sure why anyone?)
oil change
replace control arm and bushings
repalce tie rod assembly
change timing belt/tensioner/water pump/thermostat and all belts
new wiper spray pump
valve adjustment
oil pan gasket
oil filter housing
oxygen sensor
replace light bulb for obc 9 button
abs relay
fuel filter
flush brake fluid and installed new rotors/brake pads and stainless bradded brake lines
fix glove box
new tail light gaskets
upgraded DME from 153 to 173
here's a list of things done as of 9/30/14
M50 Injectors/replace fuel pressure hose
map mirror light
busted return coolant hose replace some coolant hoses
flush green coolant and replace with fresh new BMW blue coolant
ellipsoids lights
oil change
valve adjustment
oil pan gasket
oil filter housing
oxygen sensor
abs relay
fuel filter
fix glove box
map mirror light
