+ now new recirculated air is cooler ;)
Hokejka e30 m50 turbo build
Did a smoke test today. There are no boost leaks. Also no codes begin thrown.
Ill take the plugs out first thing tomorrow. No the tune is for my identical setup as i mentioned.
My waste gate was leaking but even fixed the car won't build any boost and barely idles.
I unplugged the MAF and thats when it finally drives/acts normal but still doesn't build any boost.Comment
curious as to why you're recirculating the BOV? for shits and giggles have you tried unhooking that and running it?sigpic
Instagram @rebellionforgeComment
Car is finally boosting with stiffer spring. Once it hits boost its almost as if everything was fixed. AFRs are where they should be. Once I let off, the gas/idle/and getting back into boost is a struggle, it boggs, and runs super lean, 18+.
Yes I tried running without the BOV recirculating and since its now closed it makes no difference at idle. During boost it needs to recirculate as the MAF is tuned for this draw through setup and has already accounted for the air it let in. Idealy ice like to go to a traditional setup but with this tune it will stay like this for a while.Comment
Are you sure your vacuum lines on your waste gate are hooked up correctly? I have seen people hook the tial up wrong and get all kinds of weird problems.
Do you have a boost controller or anything installed?
Also another thought to add, if you didn't change any wiring or anything else major from the original swap, I would look heavily into the turbo parts. I am sure you already knew this, but I some times like to hear people repeat the great ideas that I come up with.Comment
100% on waste gate and BOV. They were wrong originally and I just redid them. I had a boost leaks on both. No boost controller. Went mechanical and found the exact springs I need. Not sure about waste gate spring. Hopefully it won't over boost but right now its holding at least a cpl psi and shutting at idle and vacuum.
I am thinking right now two things:
1.The tiny vacuum leak I have on the manifold is enough to change the AFR that much? Could that be possible. When we did the smoke test there was a whisper of smoke coming from the idle control valve. Would the heavy negative 20lb vacuum turn that into the problem?
2. There is enough air just not enough fuel? Fuel pump or fuel pressure regulator are begin weird? I would think this for sure but the car runs amazing once it gets into boost. Just terrible out. So if they were faulty I feel like my AFR would be also super lean in boost and they're perfect where they are.
3. Im going crazy.Comment
nothing guys :/ ... replaces 3 hoses. brake booster seal. AFRs now move around between 17-18 so i guess a tiny bit lower. rpms are also a little low around 450. tried unplugging MAF and now it idles up and down not like it used to be steady. I'm really out of ideasComment
What's the fuel pressure at idle? The whole lean problem is strange seeing how you get below 13 under boost. What chip exactly do you have in? Also, the injectors are probably fine but did you check the ohms were in spec before putting them in. You said that you have a 450 idle but is it bouncing or relatively steady? Typically you'll see higher idle when a vacuum leak is involved.
Also just curious what spark gap your running.
'89 535i/5 Holset WH1E turbo
Follow my m106 megasquirt build thread: http://forums.bimmerforums.com/forum...Squirt-contentComment
