1989 Lachssilber ///M3
  • CorvallisBMW
    Long Schlong Longhammer
    • 13039
    Nice score, sub'd
    • diegom6
      • 4447
      Congrats! Looks like a solid M3 specially after 257k miles it does look very well conserved. Leather should all cracked and worn but seems the previous owner(s) took care of them.
      Enviado desde mi iPhone con Tapatalk
      Euro M3'87 NogaroSilver/Euro E34 M5 '93/Porsche 993 TT 97' Euro/Porsche 993 Carrera 95' Euro/Skyline R33 GT-R
      • bootlegskate
        • Jun 2010
        • 139
        Thanks Diego, I was also surprised at the condition of the interior. Thanks to the prior owners! BTW I am the 5th owner I believe. When I got the car, my buddy had a thick folder full of service/part/paint records.
        On another note, I just finished pumping about a 1/3 tank out of the fuel tank. I removed the full pump and sucked it all out. When I do the fuel filter on friday, I will try to drain the rest. Until then...
        DD '03 AW M3
          • 37834
          Congrats! Look forward to progress.
          Grover Beach, California
          BimmerHeads.com
          • Bmwdayz
            • Apr 2011
            • 610
            There's a drain plug on the tank on the pass side. No need to pump out fuel :)
            • bootlegskate
              • Jun 2010
              • 139
              I saw that, tried to loosen it and it was on there pretty good. I didn't want to risk stripping it. In the case that it does come out, do you put Teflon tape on it when it goes back in, or some type of thread sealer?
              I soaked it in PB blaster last night so I may try to get the rest out from there.
              DD '03 AW M3
              • *freshm3
                • 174
                Good Luck on the revival. I'm looking at a few E30 M3 rollers to tackle another S54 swap. Save up and rebuild the S14 you have.
                I wuv these kind of threads*
                If looks could kill:::
                • bootlegskate
                  • Jun 2010
                  • 139
                  Thanks man. Do you have a build thread for the s54 swap? I'll be keeping the s14 for sure, but cool to see the swap.
                  DD '03 AW M3
                  • Nats88M3
                    • Sep 2013
                    • 209
                    Nice! Keep us updated in the progress!
                    • bootlegskate
                      • Jun 2010
                      • 139
                      Hey everyone, so I started to remove/inspect some of the parts I will be replacing Thurs/Fri to get a head start ( I'm flying to china for work on Saturday and would like to get it running before then).
                      I removed the plugs and wires so I could squirt some motor oil in the cylinders. I wanted the rings to soak a couple days prior to starting the motor. Plugs actually looked pretty good along with the motor oil, they must have been changed prior to the car sitting.
                      This morning I put the rear of the car on stands and pulled the back wheels off to inspect the brakes. They are rusted, but pads and rotors look fairly unused as well. My buddy also had just put ground control coil overs on the car right before it sat so I dont have to worry about springs/shocks.
                      Also, the black tape on the front bumper looks horrible. Can you guys recommend a method to remove it without damaging/scratching the paint/trim?
                      I will be looking at tires today, can you guys recommend good tires for the Style 5's? The wheels are square I believe and are 17"x8"
                      DD '03 AW M3
                      • Todd Black 88
                        • Oct 2007
                        • 3449
                        215/40/17 for the tires if you want a no issue fit.
                        You may get some manufacturers 235/40 in the front to fit, but 235/40 will fit the rear no problem
                        Originally posted by codyep3
                        I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
                        2001 silver/Blk 325 cabby. SOLD
                        2002 325xit Sil/blk. SOLD
                        2010 F650gs twin
                        • diegom6
                          • 4447
                          My M3 use BBS CH ET15 with 235/40/17 (Star Spec) and I think it does look perfect, a good compromise between ride quality and look (too thin in these roads is a NO NO) but I'm running rolled fenders all arround. Front rub a bit at almost full lock with inner fender plastic but doesn't botter me.
                          • bootlegskate
                            • Jun 2010
                            • 139
                            Thanks for the info guys. I am going to order a set of 215/40/17 tomorrow. Im not sure if I want to roll my fenders and it looks like theres still a lot of room under those wide things.
                            Some work was done tonight, I removed the back brake assemblies including the lines. The intermediate (e30's have 6 rubber) lines look tough to get to, so I ordered a set of crowfeet sockets. Sure hope that does the trick, I don't feel like dropping the subframe. Rear diff fluid is also drained, waiting for Fridays package.
                            DD '03 AW M3
                            • diegom6
                              • 4447
                              With 215/40 most likely you won't have to roll the fenders, you should be more than fine. The issue mostly is in the back with wider tires that rub in the fender, front not so much.
                              What fluid are you going to put in your LSD (assuming is stock)?
                              • bootlegskate
                                • Jun 2010
                                • 139
                                Hi Diego, slept on it last night and now thinking of going 225/45/17 in the Michelin pilot super sports. I have them on my e46 m3 and they are good tires.
                                For the diff, I'll be using redline 75w90. Diff is stock afaik. Pretty sure it had royal purple in it.
                                DD '03 AW M3
