i bought the car about 3 years ago. the cars a 325eta 4 door, i only got to drive it for about 7 months and then the engine fucked up(timing belt) i ended up finding an m50 from a 92 e36 for cheap from a member on here
I'm getting help from a few friends since its my first car
m50 engine with beauty covers makes it look a bit cleaner
new spark plugs
new valve cover gasket
new oil pan gasket
new water pump with metal impeller
new thermostat
G260 transmission
new clutch with pressure plate, TO bearing and 10lbs flywheel
new e28 motor mounts
new condor m50 swap transmission mounts
24v transmission brace
rebuilt calipers with fresh pads and braided lines
I driveshaft
porsche brake booster
m42 radiator with e36 coolant hoses
LSD S373
euro bumpers with euro valence
Mtech1 side skirts
foha rear apron
e28 spoiler
new m20 starter
z3 shifter with new bushings
the engines in I'm just waiting on a non vanos harness so we can finsih the swap:D
new spark plugs
new oil pan gasket
new thermostat
G260 transmission
I driveshaft
LSD S373
Mtech1 side skirts
foha rear apron
e28 spoiler
new m20 starter
