Dat e30 doeee
  • 968Reckless
    • May 2013
    • 1095
    #106
    Dat e30 doeee
    Interior went in today
    /// MTech Belts ///
    S52 BUILD
    M3 VERT BUILD
    • 968Reckless
      • May 2013
      • 1095
      #107
      Well after a few months of electrical trouble shooting I finally got the car running last night. Turns out i had a bad wire harness! Now I just need to button things up and drive it!
      /// MTech Belts ///
      S52 BUILD
      M3 VERT BUILD
      • CorvallisBMW
        Long Schlong Longhammer
        • 13039
        #108
        God those seats are sexy... :fap:
        • 968Reckless
          • May 2013
          • 1095
          #109
          Took it outside for the first time in a while. Everything is running pretty good, have a slight oil leak but that's about it. Need to get the exhaust hangers welded on, wire harness cut down and some small stuff done.
          /// MTech Belts ///
          S52 BUILD
          M3 VERT BUILD
          • 968Reckless
            • May 2013
            • 1095
            #110
            Dat e30 doeee
            Replacing the oil pan gasket and adding some sealer....g260 is killing me! Trans is coming off this week.
            /// MTech Belts ///
            S52 BUILD
            M3 VERT BUILD
            • 968Reckless
              • May 2013
              • 1095
              #111
              Haven’t posted in a while as I got a new vert project but the car is almost finished. Just have some small cosmetic stuff to do and will probably rebuild the vanos.
              Got a new wire harness, had it chopped up and squeezed into the cover. Exhaust hangers welded and put some washers on top of the motor mounts to get an extra couple millimeters.
              /// MTech Belts ///
              S52 BUILD
              M3 VERT BUILD
              • 968Reckless
                • May 2013
                • 1095
                #112
                Will eventually start a thread for it but things are moving along quick.
                /// MTech Belts ///
                S52 BUILD
                M3 VERT BUILD
                • TFJR
                  • Feb 2012
                  • 561
                  #113
                  That interior and the seats are gorgeous. Where did you source the fabric and other details?
                  1988 325 Lachs Sedan SOLD
                  1989 325i Bronzit Beige 2 Door
                  SOLD
                  2018 Volkswagen Alltrack SE DSG
                  Past:1988 325iS Lachs 5 Speed
                  • 968Reckless
                    • May 2013
                    • 1095
                    #114
                    Thanks man, still a few small things to add to the interior. Fabric came from one forum member, stitched up by another and put on the seats by me.
                    /// MTech Belts ///
                    S52 BUILD
                    M3 VERT BUILD
                    • 968Reckless
                      • May 2013
                      • 1095
                      #115
                      Some minor updates: vanos has been rebuilt, crazy how much play it had.
                      Also made some Porsche RS style door pulls, added a map light mirror and added oil temp/water temp/ volt gauges.
                      /// MTech Belts ///
                      S52 BUILD
                      M3 VERT BUILD
                      • 968Reckless
                        • May 2013
                        • 1095
                        #116
                        Car has been driving good so far. Wrapped the door sills and back side of the hood. Also added some red LED strips for footwell lighting. Wired them to come on with the door sensors.
                        Mirrors are being painted after the 10th failed attempt to wrap them. So I have the cup mirrors on for a temp solution.
                        /// MTech Belts ///
                        S52 BUILD
                        M3 VERT BUILD
                        • 968Reckless
                          • May 2013
                          • 1095
                          #117
                          /// MTech Belts ///
                          S52 BUILD
                          M3 VERT BUILD
                          • 968Reckless
                            • May 2013
                            • 1095
                            #118
                            And one good pic...
                            /// MTech Belts ///
                            S52 BUILD
                            M3 VERT BUILD
                            • DIIRTY-30
                              • 1665
                              #119
                              loving the interior dude! keep up the badass work
                              BLUE NOSE - M62 SWAP
                              THE E30 + 1 BUILD
                              • Levy3Poop
                                • Apr 2017
                                • 536
                                #120
                                What wires did you hook the foot well lights up to, the dome light?
                                Fantastic work! This thread is definitely inspiring. Can't wait to see what that little vert has in store for it
