Dat e30 doeee
    Originally posted by Levy3Poop View Post
    What wires did you hook the foot well lights up to, the dome light?
    Fantastic work! This thread is definitely inspiring. Can't wait to see what that little vert has in store for it
    You tap them to the door switch wires, pull the speaker cover off and look for that wiring. You use the ground.
    /// MTech Belts ///
    S52 BUILD
    M3 VERT BUILD
    Instagram: @martino_motorsport
      Haven’t posted in a while but the car is running good. Installed an AFR and I’m at around 14.4, car still has a slow rev drop but I might just chalk that up to s52 lol. Everything I can think of that’s related to it has been changed besides the tune and for some reason the tuner won’t tell me the trim numbers he did.
      /// MTech Belts ///
      S52 BUILD
      M3 VERT BUILD
        Picked up a few new projects for winter as well, shop is packed.
        /// MTech Belts ///
        S52 BUILD
        M3 VERT BUILD
          Old pic but a good one.
          /// MTech Belts ///
          S52 BUILD
          M3 VERT BUILD
            God damn! Very big fan of this car.
            1991 sterling silver 318is
            1987 alpine white 325i convertible
              Great build. The hood up distance photo is sexyyyyyyy. Hell even the avant!
                Dat e30 doeee
                Ended up putting a new booster and master in. Booster had a leak and the internals on the master went bad. Fun times.
                Also added some brake ducts because why not .
                /// MTech Belts ///
                S52 BUILD
                M3 VERT BUILD
                  added them because without them you'll always notice they aren't there. I know that was my reason for most certainly needing to replace my broken one.
                    Exactly!
                    /// MTech Belts ///
                    S52 BUILD
                    M3 VERT BUILD
                      Giving the interior a little flare. Disassembled, cleaned, new hardware, painted and some matching m-rain to top it off. Sent from my iPhone using Tapatalk
                      /// MTech Belts ///
                      S52 BUILD
                      M3 VERT BUILD
                        Mounted it about 6” back from where it would normally go. Can slide it completely out of the way. Sent from my iPhone using Tapatalk
                        /// MTech Belts ///
                        S52 BUILD
                        M3 VERT BUILD
                          So it just mounts directly the center console piece? Seems simple enough, but does it creek or feel flimsy when using it? I know that part of the center console is pretty weak.
                            Center console and the tunnel. It’s very solid. Sent from my iPhone using Tapatalk
                            /// MTech Belts ///
                            S52 BUILD
                            M3 VERT BUILD
                              The Husco is pretty solid but mine does creak when you have a drink in the holder. Other than that it supports my boney ass elbows. I love the rain re-wrap! Nice.
                              90 Bronzit 325is
                              16 Black Sapphire 340i M Sport
                                I added a few strips of electrical tape to the slides of the arm rest to prevent it from sliding under hard braking. Maybe that why mine doesn’t creak? Sent from my iPhone using Tapatalk
                                /// MTech Belts ///
                                S52 BUILD
                                M3 VERT BUILD
