How to make a 318 into a 327i
  • James Crivellone
    Head Janitor
    • 6302
    Originally posted by Mot
    Meh, I enjoyed my 318 > 327iS swap alot more... way more ghetto.
    Yeah it was thrilling! :drink:
    • The Fast One!
      • Jul 2005
      • 856
      meh, I helped with this little shindig thingy.
      Mike Fritz
      • M42Technik
        • 9781
        Haha what did you do Mikey? Pickup tools with the magnet?
        Kidding, kidding...
        You guys want to help me fix my damn car? It sucks.
        Reminiscing...
        • equate975
          • Jun 2004
          • 3382
          2 days? Snap... I think I still win the longest engine swap ever, Easily pushed a year and a half... lol
          Rollin' with a Geistkuchen
          • The Fast One!
            • Jul 2005
            • 856
            Kidding, kidding...
            you know it! ;)
            we had this one little tool that would have been lost if it wasn't for me, lol.
            Mike Fritz
            • porsche gt1
              • 237
              Originally posted by rs4pro3
              Are you sure that engine is an M20B27 as it sure looks like a m20B25 325i engine?
              I can verify it is a M20B27 it is from a 88e. That my friends is a super Eta Engine. Good job nice swap. All you need now is a turbo on that suca.
              • adept
                • Feb 2006
                • 425
                Why would you swap in an ETA motor?
                • Bimmerfanatik
                  • May 2004
                  • 5349
                  If it's a super eta motor, as the gentleman above indicated, then I can explain why.
                  The SETA bottom end is a perfect base for a cheap but effective stroker motor built using factory M20 parts. By using this 2.7 bottom end, you get a longer stroke, but keep the compression at a reasonable ratio of 8.5:1 with the '88 MY specific pistons. The '88 SETA came with an 885 casting head (same casting as the 325i) but with single valve springs and the less aggressive ETA cam. By swapping the head for the stock i head (or swapping dual springs and the more aggressive cam) and intake mani, wiring harness, ECU, etc, you increase the rev limit of the engine, therefore substantially increasing the horsepower found in the stock SETA engine. What results is a gain in horsepower over both the stock i engines and the low HP eta engines, but also an increase in torque over the already torquey ETA engine. Lots of low end grunt, while still having lots of top end too. Increase the compression for a real fun NA stroker, or strap on some forced induction with moderate boost and go nuts.
                  Oh, and I've got one under my hood :)
                  • EtaSport
                    • 2853
                    Well, your all wrong. Its an m20b27 from an 325e automatic 9.0:1 compression. Ive already answered to why we swapped an eta. It was less expensive than an I motor, and with the motronic swap, worked eta head from my current set-up it will be faster than m20b25s. Its my same set-up that I daily, and its super reliable, torquey, and fuel efficient. I can pull on 325i's and ive got stock gearing.
                    Old and improved:
                    • nkell09
                      • Jan 2004
                      • 575
                      Etasport has let me drive his car on different occasions (before & after). Yep he's crazy.... The seat of my pants gives it a big thumbs up!
                      • EtaSport
                        • 2853
                        Yea, we've got an eta thread over on e30techer... I just posted that I'll have my "stage 2" head ready to go on this weekend. "stage 1" (my current set-up, and the one that will go on cowden's car) was a port increase, about an inch down, dual i valve springs and a standard 325i cam.
                        The new head will be increased further plus have the valves unshrouded and ported within 1/2 inch from the seat (not to exceed 80 percent of valve size). I have read this makes more gains than simply increasing the port size. Also have dual springs, and a catcams 283 degree 11.9mm lift cam.
                        Old and improved:
                        • Jhonno
                          • Nov 2004
                          • 736
                          Good work all round
                          ///M Inside
                          • Bimmerfanatik
                            • May 2004
                            • 5349
                            Maybe I'm missing something - how did you get a 9.0:1 compression by putting an i head on an eta bottom end? I thought that gave a much lower compression rate and the flat pistons of the ETA and the domed combustion chamber in the 325i head don't make the most efficient pair. If you did something different, let me know - it's late and I may have misread :)
                            • Jean
                              • 18228
                              Man, I want that front end! It's an 84 with plastic bumper or is it a tucked and painted stock bumper with valance?
                              • EtaSport
                                • 2853
                                Its an eta. Its got an eta head, 9.0:1 compression, and an eta bottom end. Its got motronic 1.1 from a 325i, and it will be getting an modified eta head and I cam to truely make it a 327i.
                                Old and improved:
