My Polish Evo 2 M3 Hood/Bumper/Trunk Gaskets
  • Klug
    • Sep 2011
    • 804
    Well I'm only 25% polish- but I do enjoy my Harbor Freight tools and making things work for cheap.
    I was doing some research a few weeks ago about the e30 M3 Evo 2 gaskets that were used on the hood/fender and bumper/valence gap. From what I saw it really cleaned it up a bit and made the lines more "modern" and cleaned up- I guess you can say.
    So instead of paying $250 for a set that I was finding, I decided to hit up Lowes and grabbed a few types of door/window weather stripping. Did a few tests and found out that the Frost King EPDM 1/4in Black matched the best for under $7/pack.
    As far as longevity, the adhesive is surprisingly strong. "Premium Rubber Foam, will not harden, crack or freeze" "Retains shape in sub-zero temperatures"
    I can't find it on Amazon, but its probably sitting at your local Lowes: Frost King 2-Pack 0.312-in x 17-ft Black Ethylene Propylene Diene Monomer Door Weatherstrips
    Per pack- it has 2 1/4 strips together in 8.5 foot sections. You could easily separate them with a sharp blade, but I ended up keeping them together for better adhesive purposes. If you do separate them you would end up with 17ft total.
    Here is what I used (keeping the two sections together)
    - (1) For both sides of the hood/fender gaps
    - (1) For the bumper/valence gap
    - (1 with extra left over) For the trunk gaps
    So for about $24 I can't say this was a bad deal. Overall, it came out much better than I could have expected. Keep in mind- I might have slightly odd gaps compared to you- my front end valance was replaced and re-welded on from a donor, so things are a little difficult to dial up straight.
    I'll be sure to update this as time goes on with how long it holds up. Hope this is good info for some people!
    555Garage - Kingston, PA
    '13 BMW e70 X5 35d
    '95 BMW e34 525i
    '92 BMW e30 325i S52 Vert (Quade the Vert)
    '92 Range Rover Classic
    '90 Range Rover Classic
    '89 BMW e30 325i Coupe (The DIRTY30)
    '81 VW MK1 Rabbit Caddy Diesel
    '76 Honda CB550K Cafe/Brat
    '67 Pontiac LeMans
    '24 Model T Depot Hack
    ....And a bunch of Motobecane, Puch, Garelli, Batavus and Honda 49cc-78cc Mopeds...
