basically u suck balls! Very nice man, Im jealous
Going to git me some cows...
very very nice.
check out www.maxbimmer.com for toronto stuff.
FYI: e30 meet this sunday in scarborough.Comment
You guys crack me up...
"basically u suck balls!" - Lol... might have to get good at it to support this habit!
Alpina goodies came from either eBay or KSK (lets just say 'exclusive' pricing). Shocks and springs from TMS.
Dead pedal would be :pimp: I have pinstripes and decals... waiting for either an Alpina motor (or reasonable facsimile) and/or repaint - next year's welfare cheques. :nice:
Alpina cluster was pretty much PnP but that may be because my stock gauges were also metric (vs US-spec miles)? I did have to recalibrate the speedo because it was set up for an Alpina diff. Pretty easy stuff, small adjustments to the pot on the speedo board and you're good to go.
King Luis - bad timing... I'm going to MTL this weekend... would like to see your bad asses... how often do you guys meet?
The E30 guys usually meet twice a year, this is probably the last one. There are still other meets, Randy Sparre's Bimmercruise is Sept 10th for example (that's the biggest show all year).Originally posted by nomsgKing Luis - bad timing... I'm going to MTL this weekend... would like to see your bad asses... how often do you guys meet?
I have 355k.Comment
The reason I asked about the clocks, is that I can get one from a 333i (Unique sa Car) it came with Alpina clocks, was wondering if it would work due to the motor being a M30.Originally posted by nomsgYou guys crack me up...
Hey SAE30, my Alpina clock came from a rare C2 2.7 touring. There's probably a good chance (amateur opinion) that the 333i cluster will work in your car. You might have to recalibrate the speedo like I did and swap the code plug with the one from your cluster. That's the white plug on the bottom-right facing the front - I believe it controls the tachometer (and fuel economy gauge). I didn't do this because the revs are reading accurate. Also, don't forget the weird things that can happen if SI batteries are toast - you've probably read about that already.
Good luck. Post pics if you decided to do it.
TN.
Originally posted by SA E30The reason I asked about the clocks, is that I can get one from a 333i (Unique sa Car) it came with Alpina clocks, was wondering if it would work due to the motor being a M30.
