I wanted to build my car in peace however after months of scavenging through the tons of information on here I decided to donate to the cause. After years of procrastinating finally took a leap of faith and drove to Connecticut to pick up this a 1992 318i with 137,000 miles.
So the deal with this car was that allegedly the oil pan suffered a hit and loss of oil caused the motor to cease up along with the starter. Car came with tons of bib parts as well as a full M20 swap. Which I was going to dump with the hopes of putting in a S52 but after being discouraged with all the custom fabrication and finding it stupid to scrap a perfectly good motor and tranny I decided to go with a M20 turbo build.
SO MORE BAD
Got the car home and decided to run through the car to really see what I had because I picked it up in the night.
Sport Seats mechanisms was kinda not optimal but no rips
Convertible top plastic window ( zipper ) stitch was all kinds of messed up so i plan on getting a brand new top.
The tumbler was stuck in the steering wheel lock so I had to use the saw trick because the pin trick was not a option. So I then had to replace the steering column lock.
The dash had awful cracks so found a brand new dash on craigslist for $200
NOW THE WORST
Eventually I will get that rust addressed and get as much rust removed as I can. My plan is to get the engine and tranny in first then send it to the body shop.
Im almost done getting the dash back in just waiting on the instrument cluster cause of course I broke the tabs.
Engine is already out and I have a lot of cleaning to do. If someone would like the help me with the best method of cleaning the engine bay? Thinkin power washer and toothbrush.
I plan to keep the stock bottom end as I don't plan to go over 400 tq but I am going to build the head with HD rocker arms and hotter cams and heavy duty valve springs. Today 02/03/2017 block is with builder being cleaned and new timing belt kit with water pump and ARP head studs will be put on.
Anyways much more work to be done hopefully I could finish up the dash this weekend.
SO MORE BAD
NOW THE WORST
