Muelleskis Brilliantrot e30
  • mabimmer
    • Aug 2018
    • 41
    1991 325 w 95 motor and transmission. Bought from a member. Just got it in the garage today.
    Lots of plans already
    Brilliantrot 1991 325-1995 BMW S50 Engine S50 intake-headers Borla Pro XS- 318is Radiator Spal 16” pusher fan Cone filter Tuned by RK- Bilstein Sport dampers with IE springs -Z3 steering rack- 16” style 5 from E32 Wilwood 4 piston Dynapro calipers -EBC pads Volkswagen Corrado rotors stainless steel lines-E32 M5 master cylinder, 325iX brake booster, 2002ti remote reservoir-1996 325i driveshaft Z3 3.15 Torsen LSD Z3 1.8 shifter IS lip and spoiler Antenna deleted Euro Grilles
  • Codym42
    • Mar 2013
    • 611
    Beautiful car! Just saw it on the facebook group earlier lol
    '90 325i - 5 speed coupe
    '05 330ci 6MT ZHP
    • mabimmer
      • Aug 2018
      • 41
      Thx had to double post. Can’t take any credit I bought it as is. There is work to be done though
      • mabimmer
        • Aug 2018
        • 41
        1995 M3 engine and transmission.
        Modifications:
        Suspension:
        Bilstein Sport dampers with Ireland Engineering progressive race springs
        Z3 steering rack (power steering deleted)
        Increased caster front lower control arm bushings
        Reinforced front subframe
        Wheels are 16” style 5 from E32 which have been filled and redrilled to 4x100 before being refinished.
        Tires are Continental Extremecontact Sport and have less than 5,000 miles
        Custom wheel spacers/center bore adapters
        Brakes:
        Wilwood 4 piston Dynapro calipers in front with EBC Yellowstuff pads / Volkswagen Corrado rotors
        Rear calipers are stock - recently rebuilt
        New rotors and pads all the way around
        New stainless steel lines
        New E32 M5 master cylinder
        325iX brake booster
        New 2002ti remote reservoir
        ABS works
        Engine:
        1995 BMW S50 Engine
        Recently replaced water pump and thermostat
        S50 intake
        Ebay equal length headers
        New Borla Pro XS muffler used as resonator with Vibrant Street Power muffler
        New 318is Radiator
        New Spal 16” pusher fan with low temperature fan switch
        New RevShift 80A polyurethane engine mounts
        New Cone filter
        Fuel pump replaced shortly before purchase
        Tuned by RK
        Driveline:
        New center support bearing with engine swap
        Z3 3.15 Torsen LSD
        Replaced all CV boots within last 10,000 miles
        New Polyurethane differential mount
        New Polyurethane transmission mount
        New Z3 1.8 shifter with all new bushings in last 10K miles
        Interior:
        Incredible black leather sport seats, amazing condition
        New blower motor and climate controls
        8 button clock
        New Renown 280mm steering wheel
        ZHP shift knob
        JVC single din head unit
        Replaced odometer gears
        Center console has been modified for cupholders
        All lights work
        External thermometer replaced
        No lights on dash
        Exterior:
        Resprayed in summer 2018 by Paintworx in Albany NY. 2 stage. Brilliantrot. Window trim removed but all windows remained in.
        New Morimoto HID’s in stock Ellipsoid housings
        Perfect condition fog lights
        Almost every piece of trim has recently been replaced
        IS lip and spoiler
        Antenna deleted
        Sunroof works perfectly
        No leaks
        Tail Light seals replaced
        New Euro Grilles
        All lights work
        Some rock chips in front valence
        • mabimmer
          • Aug 2018
          • 41
          Now have full ground control coil over kit with camber plates, converted back to power steering with a rebuilt ZF pump and a chase bay kit with cooler. Installed vented back plates. Purchased black door cards just need to find a good back seat and new carpet. New wheels and tires as soon as I can find the right info on fitment. Looking for side skirts as well
