The white pearl
  • hendrixvodu
    • Jan 2007
    • 2514
    The white pearl
    Hey guys it’s been a long time since I have posted a build but I figured this one is worth sharing!
    So I’ll introduce you to the white pearl, I call it that because the car was a very neglected 1989 325i sedan repainted pearl white. With the being said you’d think ... gross. But ! This was a virtually rust free New England car that has only been painted 1 time in its life ! That’s a rarity that I’m sure all New England car guys will agree with.
    So I found this car on Craigslist for $2500 and upon looking at that pix it seemed well worth a look. So I get intouch with the owner and he sounds to be close to my age/generation, he says come by and check it out ! So I head over and meet his father ... clearly not a car guy at all but very friendly. Story on the car is it hasn’t been on the road for 10 years it needed a “sensor” he stated because it would die and not restart. He’s telling me this information as the car is running, durning his story im looking over at the motor and notice the head is smoking (great sign) open the coolant res and it’s dead empty. So I look the car over and it literally has NO rust , interior is trash, tires dry rotted, painted by a person with little to no vision. I tell the guy that I’m fairly familiar with these cars and I said I’m fairly sure it needs a motor, we talk for a bit and I say “listen I’ll give you $1000 and I’ll get it out of here today” he agrees and I come back with a truck and trailer and bring her home.
    *I apologize for any punctuation or grammatical errors, I’m really bad at writing*
    -His-
    87 e30 325i
    87 e24 m6
    05 e83 x3
    94 e32 740i 5spd
    -Hers-
    89 e30 325i
    18 f48 x1
  • Jokester
    • Sep 2016
    • 1818
    Fix the kidney ASAP. Excited to see it come back to life. Good pickup for 1k
    • hendrixvodu
      • Jan 2007
      • 2514
      *I will slowly update this as I have a ton of pix!*
      -His-
      87 e30 325i
      87 e24 m6
      05 e83 x3
      94 e32 740i 5spd
      -Hers-
      89 e30 325i
      18 f48 x1
      • hendrixvodu
        • Jan 2007
        • 2514
        So as I get into the car I find some small rust spots ... still this is NOTHING compared to what I’m used to seeing on e30’s
        -His-
        87 e30 325i
        87 e24 m6
        05 e83 x3
        94 e32 740i 5spd
        -Hers-
        89 e30 325i
        18 f48 x1
        • hendrixvodu
          • Jan 2007
          • 2514
          The piece was cut off a donor car and welded on by my brother this was just primed no filler
          -His-
          87 e30 325i
          87 e24 m6
          05 e83 x3
          94 e32 740i 5spd
          -Hers-
          89 e30 325i
          18 f48 x1
          • hendrixvodu
            • Jan 2007
            • 2514
            Removed sound deadening and cleaned floor found small rust spot near trans tunnel
            Floor repair
            -His-
            87 e30 325i
            87 e24 m6
            05 e83 x3
            94 e32 740i 5spd
            -Hers-
            89 e30 325i
            18 f48 x1
            • hendrixvodu
              • Jan 2007
              • 2514
              Fast forward a little and I’m preparing to remove the motor at my shop! Luckily I had a really nice 91 vert with a 120k on its m20!
              -His-
              87 e30 325i
              87 e24 m6
              05 e83 x3
              94 e32 740i 5spd
              -Hers-
              89 e30 325i
              18 f48 x1
              • hendrixvodu
                • Jan 2007
                • 2514
                So a little info . I know some people could give a shit less, I myself usually skim through and look at the pix! But To each his own ! I’ll just put a little info in between, so I originally bought his car for myself but this e30 ended up fitting my girlfriends needs better than mine! She has an 87 5spd vert and we are basically trading cars. So I’m building this car for her :)!
                -His-
                87 e30 325i
                87 e24 m6
                05 e83 x3
                94 e32 740i 5spd
                -Hers-
                89 e30 325i
                18 f48 x1
                • hendrixvodu
                  • Jan 2007
                  • 2514
                  So right around here is where I’m sure we can all figure out why the motor is coming out
                  So here’s what happened! Upon going over this car I found the fuse removed that controls the SI board and various other items. I replace that fuse and I find that the SI Board has failed and is constantly illuminating the red square. Well in the infinite wisdom these guys had for some reason thought that light was killing the battery (I’m assuming) and pulled it... disabling the temp gauge, I then found the throttle body heater gasket had failed . Put it all together ... the tb gasket continued to leak till there was no coolant and they just kept going haha
                  -His-
                  87 e30 325i
                  87 e24 m6
                  05 e83 x3
                  94 e32 740i 5spd
                  -Hers-
                  89 e30 325i
                  18 f48 x1
                  • hendrixvodu
                    • Jan 2007
                    • 2514
                    Bye bye !
                    -His-
                    87 e30 325i
                    87 e24 m6
                    05 e83 x3
                    94 e32 740i 5spd
                    -Hers-
                    89 e30 325i
                    18 f48 x1
                    • hendrixvodu
                      • Jan 2007
                      • 2514
                      Here comes the new one ! Haha
                      -His-
                      87 e30 325i
                      87 e24 m6
                      05 e83 x3
                      94 e32 740i 5spd
                      -Hers-
                      89 e30 325i
                      18 f48 x1
                      • fresh_TD
                        • Aug 2013
                        • 2457
                        Good progress!
                        Sent from my Pixel 3 using Tapatalk
                        '91 318i (Alpine) - daily
                        '88 325ix (Zinno) - drive here and there!
                        • hendrixvodu
                          • Jan 2007
                          • 2514
                          Did the timing belt water pump
                          -His-
                          87 e30 325i
                          87 e24 m6
                          05 e83 x3
                          94 e32 740i 5spd
                          -Hers-
                          89 e30 325i
                          18 f48 x1
                          • hendrixvodu
                            • Jan 2007
                            • 2514
                            Motor in
                            -His-
                            87 e30 325i
                            87 e24 m6
                            05 e83 x3
                            94 e32 740i 5spd
                            -Hers-
                            89 e30 325i
                            18 f48 x1
                            • fresh_TD
                              • Aug 2013
                              • 2457
                              You work super fast
