So I bought this car some time ago from a guy in Houston.
He did a lot of suspension work to the car and it handled like it was on rails
So far here is the build
Bilstein b8's
H and R race springs
Garagistic drop hats
Garagistic urethane bushings every where
Garagistic Solid steering coupler
Garagistic aluminum front diff mounts and green urethane rear mount
Garagistic front and rear strut tower bars
2.93 LSD medium case
UUC front and rear sways
ECS clutch and brake lines
Blank rotors ebc red stuff pads
Z3 rack with garagistic mounting kit
AKG motor and trans mounts red
AKG short shifter kit
AKG DSSR
Clutch masters clutch
Condor brass fork pivot
RHD 7lbs flywheel
Ac and power steering deleted
EBay header to 2.5" mandrel bent exhaust with magnaflow resonator and sport muffler
Condor speed shop mspnp2 management tuned by sanoli performance mcallen texas
Afm deleted
Icv deleted
3" cold air intake
Square Motorsport e36 tps adapter
Clutch fan delete
Flexalite 16" fan with controller
AEM eugo with controller
Walbro 255 pump
23.5lb injectors
IRE 8mm wire set
Schrick 284 cam
Febi HD rockers
Condor center vent gauge mount with bosch gauges
Bulgarian made steering wheel
Sparco corsa seats
This is how it was when I first bought it
Current look
My buddy ovi wrapped this plate I built to install my radio
Turned out pretty sharp!
RHD flywheel
Coupler installed
AKG shifter
That brain
Yes I plan to clean up the wiring now that it's all figured out. If anyone has some clean examples how to do that that would be welcome!
Little interior shot
First ever dyno run
Sanoli performance!!![emoji3590]
Installing this days off!
Bilstein b8's
AKG DSSR
RHD 7lbs flywheel
Afm deleted
Icv deleted
3" cold air intake
Clutch fan delete
Walbro 255 pump
23.5lb injectors
IRE 8mm wire set
Schrick 284 cam
Febi HD rockers
Sparco corsa seats
Current look
RHD flywheel
Coupler installed
AKG shifter
That brain
First ever dyno run
